Xray X1 - Formula One Car
#2371
Thanks for reply
So for outdoor PIT tires you use soft in front 571 and hard in rear 572? Don’t they have pre glued set
CRC is it RT-1
CRC is it RT-1
#2372
https://www.amainhobbies.com/schumac...xg-571/p469211
https://www.amainhobbies.com/schumac...xg-572/p469330
#2373
In Fenix, we're proud to release our OPT038 - Wide Front End kit for Xray X1
This kit creates a 3mm wider front track width that will be helpful in high grip conditions.
Car will be less aggressive and chances of traction rolling are reduced.
#2374
Hi guys,
I have a big problem where the car feels nice everywhere except high speed corners. Especially sweepers where if i use even slightly too much steering lock, the car snap oversteers.It has a bouncing/juddering sensation as it does it.
I've tried softer and harder springs all round, thicker damping front and side, more front droop, less front droop, different camber.
Im totally lost as to how to fix this. Does anyone have any experience of fixing this problem?
This is on ETS carpet and Volante tyres, so maybe a little less grip than many of you experence where the black crc carpet is used?
Thanks for any help!
#2375
Hi guys,
Hope that helps where to look
#2376
thanks for your tips. I don't think its any of them though?
The height is 5mm at the rear and 4.8 at the front.
The tires are a control tire so everybody is on the same one type.
additive is controlled, and i'm applying it across the full surface of the tires both 30 minutes before the race front and rear, and 30 minutes rear but only 2 minutes front.
Thanks again
Thanks again
#2377
The XRAY X1 is one of the models of the Luxury car. Formula 1 racing is the head of racing technology where performance and technology-based physics challenge too much law. It has All new shock adapter for fast and easy shock piston change; New facade location and advanced power trash for improved drivability on the opposite conditions.
Update Features:
*Adjustable anti-roll bar
*Arm mount plate
*Shock spring collar
*Central mount plate
and some vital others updates.
Update Features:
*Arm mount plate
#2378
Thanks again
Thanks again
Too much front wing downforce. If you use montech front wing, remove all flaps. If it is the old montech version which has too much downforce even without flaps, try the new one or cut some material from the upper edges of the wing.
#2379
Hi guys,
if the entry is the problem, you can flatten the angle of the central damper , (less weight transfert)
add some droop at the rear
less ride height at the rear , more at the front
it's a good start
#2381
1) In case you haven't, make sure chassis isn't touching at wide points (like where they narrowed it for the 2018 update) I clean and wax the bottom of the chassis with Maxima SC1 New Bike in a Can | TwistedThrottle.com
2) Replace springs - Throw out old ones and install brand new springs of same part number - these springs only have a certain number of runs in them and they get weak
3) Diff is set improperly - getting the diff setting on the factory diff takes a little practice and a good "feel" for it - the rear end sounds like it is locking up, with traction so high (even on ETS carpet) the line between tight good and too tight and bad is a very fine line
I removed all the front droop on the car somewhere in the middle of making the car handle right, so not sure how much that helped the snap loose problem, but I have all the droop shimmed out of the front kingpins, saw a few setup sheets with the same kingpin shimming and just went to that and was happy with it
Hopefully that helps
#2383
Tried the car without front swaybars last weekend, my car got faster. I was using Xray 1.5 front springs.
#2385
subscribed
