Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 10-28-2023 | 06:09 AM
  #3646
Stephtruc's Avatar
Hi team,
Has anyone tried the carbon down stop droop plate from Makerrc ??
It doesn't work very well on my SRX the front arms no longer move freely.
Not possible to use... very disappointed.
Stephtruc is offline
Old 10-29-2023 | 04:37 PM
  #3647
IndyRC_Racer's Avatar
Are these the parts you are using? https://makerrc.com/products/low-fri...7t-f-r-2-bando
When using any aftermarket upgrade, it can be possible that the machining on specific parts may not be perfect. I would contact the company of those parts to see if they have any recommendations or suggestions on improving the free moving of suspension. You may need to lightly sand parts/remove material.
An alternative option can be found here... https://www.thercracer.com/2023/10/t...420-lower.html
This web page has detailed pictures of the parts installed included part numbers of any Tamiya part you might need.
IndyRC_Racer is offline
Old 10-29-2023 | 06:56 PM
  #3648
Interesting thread, thanks for the knowledge shared
Sam Hillary is offline
Old 10-30-2023 | 10:07 AM
  #3649
Stephtruc's Avatar
Rear axle
Front axle
All 4 carbon parts are same for front and rear....
Old 10-31-2023 | 03:11 PM
  #3650
Did the droop plates come with any type of installation manual or guide?
Do the 4 carbon fiber pieces with holes go over the suspension shaft adapters or do they replace existing spacers?
Old 10-31-2023 | 03:32 PM
  #3651
I've picked up a few used TT-02s kits. Each of them had a bent suspension shaft - Tamiya Part# 9805681. This is a 3x48.5mm shaft. After searching online I found that ARRMA also makes a 3x48.5mm shaft/hinge pin. - ARRMA #ARAC5029.
I used the ARRMA part on the TT-02s kit with no issues. Hopefully this info helps if someone is having a hard time getting the Tamiya part.
Here are a couple of links to those parts...
https://www.tamiyausa.com/shop/7-dig...m-shaft-58261/
https://www.arrma-rc.com/en/product/.../ARAC5029.html
Vertebreaker likes this.
Last edited by IndyRC_Racer; 11-02-2023 at 01:15 PM. Reason: changed 3x48.5m to 3x48.5mm
Old 10-31-2023 | 05:45 PM
  #3652
Stephtruc's Avatar
Carbon parts go over shaft adapters.
Problem is solved, makerrc will ship me updated new parts.
Old 11-03-2023 | 02:49 PM
  #3653
JEFF.777's Avatar
Just picked up two tt02's for box stock class. Any tips or tricks?
JEFF.777 is offline
Old 11-03-2023 | 02:51 PM
  #3654
DirkW's Avatar
Box stock as in not even ball bearings allowed?
DirkW is offline
Old 11-03-2023 | 03:22 PM
  #3655
If they allow it, grab some low friction suspension balls. They help out with some of the slop in the suspension arms.
Otherwise paint your dogbones a bright color (easier to see them of they fall out), and run an aftermarket servo horn if they are allowed. The kit servo savers aren't too great, of course you could try gluing the kit servo saver.
Finally, unless if they're really picky about how you setup your diffs. You can sneak in a little bit of an earplug into the front diff to stiffen it up.
Revolter22 is offline
Old 11-03-2023 | 04:50 PM
  #3656
JEFF.777's Avatar
Bearings are allowed, I have bought some bearings. I've read these have a lot of steering slop so I plan on shimming the front end up
JEFF.777 is offline
Old 11-22-2023 | 03:12 AM
  #3657
Hey, i am just fooling around and bought a TT02SR kit
Got some blue parts and some carbon here and there, but now I'm just wondering
Can you make 251mm wheelbase out of it?
Like switch out rear lower arms?
NoBrainer is offline
Old 11-22-2023 | 03:42 AM
  #3658
DirkW's Avatar
AFAIK that's not possible with the improved suspension of the "S-Type" cars, only regular TT-01 (incl. R, RR, etc)
simple likes this.
DirkW is offline
Old 11-22-2023 | 04:14 AM
  #3659
Thank you very much!
Old 11-22-2023 | 07:16 AM
  #3660
Rick Vessell's Avatar
Originally Posted by Stephtruc
Hi team,
I used my dremel to add some clearance to the plate under the arms. I also found beveling the inner edge allows it to sit against the chassis better.
Rick Vessell is offline
