Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 07-20-2022 | 09:16 AM
  #3361
simple's Avatar
Originally Posted by MikeTKD
I forget if the TT02R comes with ball bearings. Don’t forget to purchase those.
It does, full set is included.
simple is offline
Old 07-20-2022 | 06:05 PM
  #3362
Originally Posted by Raman
Spool makes the car much easier to drive, unless you put it in on the wrong end 😉
ProSpec is sssssllllllloooooowwww racing.. you can sip your coffee while going down the back straight and still have time to make a correction lol.
Are you using the Spec Gravity motor for that class?.. answered my own question... Reedy FT....
Robio is offline
Old 07-25-2022 | 02:59 PM
  #3363
Bondo21d's Avatar
Default No servo saver?
Thoughts on just skipping the servo saver? After one race weekend stock is trashed. Car is otherwise stock aside from bearings. I know the Tamiya high torque is really good, but I have servo horns in my parts box from racing off road years ago and that will save the trip to the LHS, assuming they have it or can get it this week.
Bondo21d is offline
Old 07-25-2022 | 06:09 PM
  #3364
simple's Avatar
I don't know about you, but I tend to feel that my time is better spent than changing gears in expensive highspeed servo's. It only takes one bad day and you'll never second guess yourself again.
The Tamiya High Torque is the only other servo saver I use rather than the Xray X-Stiff Composite servo saver that I run in almost all my cars.
Raman likes this.
simple is offline
Old 07-26-2022 | 04:58 AM
  #3365
FWIW, when I used the Tamiya Hi Torque servo saver, it wasn't long before it wouldn't return to center when bashing. Since going to a power hobbies solid horn, I've had to change the gears one time in my savox in 8 months of hard bashing, and that was only cause I hit something at very high speed.
Me personally, I'd rather spend ~$15 on a metal gear set when needed instead of dealing with a servo saver that no longer centers properly. I'm sure that issue could be even more annoying if you're actually racing. All my cars now have a solid servo horn aside from my budget TT02, which has a secondhand Kimborough servo saver.
The Kimborough servo saver is a good option if you don't want to run a solid horn; but if you run a solid horn, I'd recommend a robust, quality metal gear servo.
TurboThirdGen is offline
Old 07-26-2022 | 02:36 PM
  #3366
Raman's Avatar
+1
Xray servo saver is first choice, especially when racing. Tamiya is pretty darn good.. does wear.. but moving parts wear.
I’d rather replace a servo saver than gears in servo. You’re not just chipping a gear when you go direct, there is other collateral damage that in the long run will ruin the servo.. so unless it’s a cheap $20, use a servo saver
simple likes this.
Raman is offline
Old 07-28-2022 | 04:47 AM
  #3367
Default Setup help
Hey
I am currently setting up my tt02 for some parking lot racing. I am just getting back into it after a few years off. Please comment on my setup, any direction would be appreciated. My concern is the FDR is way off. Plus I am struggling to get no rebound in those shocks, any tips?
Sport tuned motor 64p 95t/43 FDR 5.75
Yeah 55mm shocks 500cst with 3 hole and front and rear red springs soft. from the yeah kit.
Ride height 5mm front and back
gear diffs front and rear
front diff 20k
rear diff 8k
CVD front and rear
Fully ceramic bearings cage and rollers.
hard chassis
3.0 degrees rear toe in
1.0 front toe out
Zoo racing hellcat body
HW 1060 esc
gwhiz likes this.
zleader_99 is offline
Old 07-28-2022 | 12:12 PM
  #3368
Raman's Avatar
ZLeader
Gearing: You need the yeah racing motor mount if you don’t have it. The maximum gear combo I have been able to fit in TT02 is 78T / 53T 3.83 fdr. This was with a brushless 21.5. You will need to trim the gear box cover or even cut a hole out to clear the large pinion.
Now with a sport tune however, an FDR of 3.8 will heat the brushes and launch them inside the motor lol.. I’ve experience it first hand. So you’re probably need to gear it to 4.5 fdr tops.
Springs: Try a different brand spring.. yeah racing springs rates are an unknown for racing, so hard to say what you need.
Raman is offline
Old 07-28-2022 | 12:37 PM
  #3369
zleader 99, have a look at my post Tamiya TT02 Thread for the mods I made to accommodate brushless
SteveM is offline
Old 07-28-2022 | 01:42 PM
  #3370
Thank you both for the insite. I did install the highspeed gear set and the Yeah motor mount I had it out this afternoon doing some practice in the school parking lot. The motor was a little warm. I changed to a 41/95 with an FDR of 6.0ish. I will try that tomorrow,
As for the shocks, I have ordered the TRF 55mm however they are on back order, I tried the TRF springs on the yeah 55mm shocks. DId not seem to work well, I could not get the right hight in check . I will try the red rear and blue front from the yeah kit. Hopefully that will correct my issues untill the tamiya shocks come in. I am having a trouble getting no rebound on the yeah shocks.
I am stuck to using the tamiya brushed motors for our club race. We run box stock silver can and chassis with bearings The mod class is bascially any add ons. However Brush motors Torque or Sport tune and the HW 1060 or Tamiya version.
SteveM I will check out your post shorty.
Is there a big difference run the TT02 with the TA05 suspension? I looking to set one up for parking lot and one for carpet.
Old 07-29-2022 | 06:46 AM
  #3371
MikeTKD's Avatar
Originally Posted by zleader_99
Hey
What class are you planning on running first?
MikeTKD is offline
Old 07-29-2022 | 07:48 AM
  #3372
Raman's Avatar
zero rebound, you need to drill a hole
in the cap, same is needed with TRF shocks.
when you say right height, is it due to the springs being too soft? Too short? Post pictures we we can help
The TA05 style suspension that comes with the type S if allowed is much better suspension geometry. The arms are longer, better ability to adjust camber, roll centre etc. you also can opt for the down stops which will give you droop control.
Raman is offline
Old 07-30-2022 | 01:11 AM
  #3373
Thanks for the tip on the drilling the cap. Are the TRF shocks any better than the Yeah? For my level of racing I highly doubt it.
When I used the TRF springs on the Yeah shocks I could not obtain the ride height. Standing the spring next to each other the Tamiya was a coil or two longer. When I get home I will take a picture.
I found the Yeah Red on the rear and yellow up front worked for a starting point. Using 500cst oil. Sunday I plan on doing a club racing. I will see how it goes.
So far the only issue I have had was a bent turnbuckle in the upper front adjustable arm. I was able to replace it with a Ti one from an xray t4 kit I found. Hopefully that will tighten up the front a little.
Old 07-31-2022 | 10:57 AM
  #3374
I do believe I bought the wrong spring set, thats why I was having trouble setting the ride height on the YEAH shocks.
Correct me if I SHOULD have bought the soft kit.
Old 08-13-2022 | 06:36 AM
  #3375
Sorted the spring issue out. I did not know Tamiya had so many types of TC springs. The one I pictured above is the right one. I ended up using the Yellow (medium) for the front and a Blue soft from the 53163 road rally spring set.
