Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 09-04-2019 | 01:38 PM
  #2131
Hoyle33's Avatar
Post continued ... the provided screws fit into the holes, but not as deep as I’d like
Hoyle33 is offline
Old 09-04-2019 | 05:49 PM
  #2132
Hoyle33's Avatar
Disregard the two last posts, I was able to get the gear to fit. My TT-02 is actually pretty fast on 2S with the gear change now! Yah hoo!
But now, I need to make some other upgrades. Going from forward to reverse and vise versa, I would hear a nasty grinding noise. And once I got to max speed (30-35mph), my steering would pretty much go into a death wobble.
Suggestions?
Hoyle33 is offline
Old 09-04-2019 | 11:47 PM
  #2133
You should have put in the screws from the other side in order to fix the spur gear correctly.
See the manual of high speed adaptor fir proper assembly.
Does the blue adaptor fit completely into the recess of the spur gear?
Both have to fit together without gap. Otherwise spur gear can wobble and do crazy things and kill itself and the pinion gear or some bearings.
Recheck these things before next driving!
JJ100179 is offline
Old 09-05-2019 | 05:08 AM
  #2134
Hoyle33's Avatar
Yeah, I noticed my screws were in the wrong way, I fixed that. Are there other gears I can used that don't have such a tight fit? I assume I won't be able to get them apart without cutting the spur gear off.
It's a 64P 70T spur gear. The only one that I can find online that fits the high speed gear set mount is the Arrowmax, which is just too large. I had to trim the edge of the gear with a knife to BARELY get the mount attached.
Hoyle33 is offline
Old 09-05-2019 | 05:37 AM
  #2135
MD's Avatar
MD
Kimbrough
MD is offline
Old 09-05-2019 | 05:43 AM
  #2136
Hoyle33's Avatar
Originally Posted by MD
Kimbrough
I do not see a 64P 70T spur gear for sale there ... am I blind?
Hoyle33 is offline
Old 09-05-2019 | 06:11 AM
  #2137
MD's Avatar
MD
Here are some and it seems Xenon Racing is the best bet. There is one source overseas and one older RW racing gear.
https://www.tqrcracing.com/shop/prod...asp?p_id=13851
https://www.michaelsrchobbies.com/xe...r-64p-70t.html
64P Spur Gear , 70T #RO-SG6470 - Race Opt - Spur Gear
https://www.ebay.com/itm/G64-3070-EX...EAAOSwkktc6IpW
Xenon Racing - Ultimate Machine cut spur gear 64P 70T
https://www.apexrc.com/products/rw-r...diff-spur-gear
MD is offline
Old 09-05-2019 | 06:43 AM
  #2138
Hoyle33's Avatar
The Xenon Racing gear looks perfect without that outside lip, thanks!
Hoyle33 is offline
Old 09-05-2019 | 07:19 AM
  #2139
MD's Avatar
MD
You're welcome.No problem, If they work well you may want to order an extra. You may want to consider other sizes that are more available.
MD is offline
Old 09-05-2019 | 07:36 AM
  #2140
Hoyle33's Avatar
I like the performance I'm getting out of the 64P 53T pinion / 70T spur combo, but I am open to other suggestions as well.
Hoyle33 is offline
Old 09-05-2019 | 07:53 AM
  #2141
MD's Avatar
MD
If you can get to the same FDR with a different gearing combo with a more common spur it might be good or just stay with it. Just buy an extra gear or two.
MD is offline
Old 09-05-2019 | 04:28 PM
  #2142
Airwave's Avatar
Originally Posted by Raman
Spool is the way to go on black carpet.. hands down.
Why?
Airwave is offline
Old 09-07-2019 | 05:51 PM
  #2143
Built this kit last year for fun. Now set up for rear wheel drive only. 19-turn brushed motor. 40mm cooling fan wired to a small voltage regulator to set desired fan speed. Chassis cutout made under motor for additional air flow. Stock kit TBLE-02S speed control with 3.5mm banana plugs for motor connection and TRX plug for battery.
Some of the optional, non-kit parts to finish the build are: ball bearings, Yeah Racing 55mm oil filled shocks, aluminum motor mount, Robinson Racing 24T mod .6 steel pinion gear, metal suspension balls for front steering knuckles, Tamiya hard tire sponge/insert, lightweight M4 wheel lock nuts. Most screws used are M3 socket hex variety.
Differentials were built with steel M2 flat head socket hex machine screws with low profile aluminum washers. Longer than the stock kit self tapping screws, going deeper into the diff case to make for a more rigid, stronger diff assembly. Diff internal is filled with sticky Tamiya anti-wear grease. 0.2mm thick 8mm shim installed for better diff gear mesh.
jneezie3000 and rippen like this.
userst is offline
Old 09-22-2019 | 11:47 AM
  #2144
proliteandsc's Avatar
Default Motor brake in
I have to use stock brushed motor for racing. New motor make the car fast but falls off within a few races. Will braking in a motor make a difference? What is the best way to do that if it will?
proliteandsc is offline
Old 09-24-2019 | 04:06 PM
  #2145
Raman's Avatar
Default ABOUT TIME
54926 TT-02 Lower Deck (Hard/Black)
yay Tamiya
Raman is offline
