Tamiya TT02 Thread
#1381
It depends on the body. I tried to look up stats for that body and it didn't list the wheel base. It's probably 257mm so build it with the longer wheel base and low ride height
#1382
Just ran two packs through the TT02 with the Suzuki SX4 body. Pretty amazed at the difference in feel over the Porsche body, feels like she changes direction much faster and tends to under steer more, I am chalking that up to less overhang both in the front and rear.
The ride 26MM Radials sure put off a lot of dust.
Cheers,
Jim
Cheers,
Jim
#1385
so using 64/25 and set it without turbo now as a start...the weather here is hot so would like to see the temp first.I also replaced quite a lot of stuff for its power...piece by piece through out the month
propeller shaft, universal drive, rear toe in, suspension...will try upload a photo later if possible
#1386
Yea, my motor is 10.5T
propeller shaft, universal drive, rear toe in, suspension...will try upload a photo later if possibleThe rear toe blocks make a HUGE difference, I used the YR ones as they were cheap but the difference in predictability was truly night and day.
Cheers,
Jim
#1387
#1388
Just tested my TT02 with 10.5T brushless, really powerful but need to study and adjust my suspension, probably need to change tires too. Got moderate oversteer when exiting corner...the power is very different from my silver can previously
#1391
I am using tamiya racing slick (#50454)...same set when I using the silver can
I am running on a local tarmac track, my suspension is TRF special damper, front blue spring, rear yellow already. Front diff ~100k and rear diff dry. The setting is fine when I use sliver can previously, I will try to play around the suspension position, may be slightly thicken the rear diff and adjust camber??...but the best is try different tires I guess
#1392
Raced in USGT yesterday.. car was consistent, I wasn't lol..
Towards the last minute of the race, I noticed my front end was seriously diving in the turns. When race ended, I noticed the right tabs of gear box cover in front were broken.. when I pulled the car apart, the left tabs were also broken lol. I'm lucky the whole thing didn't detach and spit my diff out
We now have a white and blue tub that is carbon infused but not the other parts. Shame because the gear box covers need it.
I think I have come up with a sway bar solution, will post pictures if it works
#1393
So for all white and blue tamiya parts are carbon infused or hardened? If so then I will consider them when my parts break...
Look forward to see your swap bar solution as TT02 don't have this option by default...
#1394
Only the hardened chassis is stronger than kit. The other parts are just coloured.
The hardened gearbox parts were on the grey sprue included in the TT02D chassis (although not in TT02 kits with shells)
#1395
Yet another GREAT result for this car. The track was SUPER hot (temperatures hit 100 F), first qualifying went well....got second to my main rival after a really good battle with him all heat. Second qualifier didn't go so great, got bumped out on the first corner and landed on my lid and the corner marshalls just took their time and casually walked up to flip over the car, no urgency at all. Rather than driving pissed off and overly aggressive I just pulled off to fight another day.
A-Main - Started 3rd due to my 1st qual result. Brand new Sorex 36r's. Car was fast right out of the gate, great start passed the two cars ahead in the first corner. Built up a commanding lead, walking away with it. Minute and a half left I got tangled with a backmarker and somehow the shunt wriggled lose a body clip holding the battery in place. When the marshall flipped the car my battery came loose. I quickly grabbed a body clip from the rear of the car, held down the battery. I ended up finishing 3rd but recorded fastest lap, shaving off 3 seconds from my previous fast lap.
Really really happy with the car right now, looking forward to TCS in a month
1387Likes
