Tamiya TT02 Thread
#1396
#1397
This is great to hear that you guys have your TT02's going well on the track. I really may have to make it down to the local indoor carpet track after the craziness of summer is over and give it a go. The last time I drove on a track must be 20 years ago with a TA-03 and I was moderately competitive back then. With the TT02 I have been setting up a make shift track on a tennis court and just practicing hitting the apexes and having fun. By the time the fall rolls around I hope that I can get around the track without embarrassing myself.
Cheers,
Jim
Cheers,
Jim
#1399
For future reference, part number for the grey reinforced pieces Qatmix mentioned is 9000614
#1400
#1404
Hey guys,
Question for you. I have about 20 full packs (5 hours run time) through my TT02 now and in the last couple of packs I have started to get an fairly loud intermittent clicking. It is hard to pin point where it is but it sounds like it is in the rear. I took the gear cover off and the spur/pinion (64P) were a bit dirty but it did not look like there was any debris in there but I cleaned the gears with a toothbrush and lubed it with a drop or two of tri-flow. The out drives and drive shaft seem to be fine, I have not taken the diffs out as of yet but they are both smooth. Thoughts?
I imagine I will put another pack or two through it tonight and will see if cleaning the spur/pinion had any effect.
Cheers,
Jim
Cheers,
Jim
#1405
Hey guys,
Cheers,
Jim
Cheers,
Jim
When you hear clicking? Full throttle/braking/closing throttle?
My TT02 got clicking sound when I start applying throttle slowly. I found that it's coming from the spur/shaft side as there's some kind of space in the rear gear box, when it start to spin then it will produce a clicking sound but just 1 time until full stop. I don't really look into it yet as it seems no harm...
#1407
How loud is it
When it clicks it does it anytime the car is in motion.
It is weird because it is intermittent but it does not seem to effect anything. I did notice some fore/aft play on the spur gear with the "High Speed Gear Set" and was wondering if that could be it.
I also wondered if it was something getting into the outdrives because it stopped after changing the battery and I shook debris out of the tub at the same time.
It is just annoying because the car is fairly quiet until the clicking starts.
I guess I could just keep running it until something fails
Cheers,
Jim
#1408
Check the diff ring gear and bevel gear backlash. If your diff has been installed 100% stock i.e., unshimmed (as opposed to putting a shim on the ring gear outdrive to adjust the backlash between bevel and diff) it may have worn enough to allow the odd click when the bevel jumps a gear tooth under hard acceleration. This will be more pronounced when the car has good traction as it'll feed the torque back into the transmission rather than simply wheelspinning it away.
#1409
I will run her tonight and see how it sounds with the cleaned and lubed spur/pinion. If the clicking persists I will open up the rear and dig a bit deeper.
Thanks all.
Cheers,
Jim
#1410
Thanks for the feed back. The diff assembly is shimmed in the housing and, at least when it was built, had very little slop. With that said it may have "loosened" up a bit from usage.
Thanks all.
Cheers,
Jim
Thanks all.
Cheers,
Jim
Another thing to check is to pull the motor out completely the next time you hear a click and spin the spur by hand. Do you still hear the click? Do you feel a click? If not, then you probably have a spur/pinion issue. If you do still hear it, pull the center shaft and spin front and rear independently. Which one clicks? Etc... Work you way out until you find your issue.
Or, just wait! Eventually, whatever is clicking will fail.
1387Likes
