Tamiya TA05 Touring Sedan
#6436
Originally Posted by jjl
Newb to this thread - question - putting together my TA05, and at step #19, when i attach the "rear stiffener" part K1 (which is actually in the front of the car?), the tie rod adjuster cup rubs against the underside of the stiffener on the right side (the 'scoops' molded into the stiffener), so the steering assembly can't turn right without coming into contact with the stiffener. Anyone experience this and know a fix? i don't think i put together anything wrong. seems like i have to scrape out some of the underside of the stiffener? this can't be right. anyone? thanks
#6437
thanks for the suggestions. turbonium - if you're talking about part K2 in step #17, i thought that could be the problem, but if you look at the instruction manual at step #17, it looks like that part is supposed to be installed with the subtle "v" shape pointing towards the front bulkhead, as opposed to having it fact to the rear, which is the way i installed it. Maybe i'll try flipping it around anyway so that the v faces the rear.
vlocity - i'm definitely installing K1, not K10, so that's not it, but thanks.
#6438
Im building this kit up too at the moment jjl, but with a 3racing graphite chassis.
If I get up to that step soon i'll bear this topic in mind and take a few pictures of how mine went together
I've only just finished building the diff's...
#6439
Right, I did theis, the steering assembly on the right, you got it upside down, take it off, flip it over, put the ballstuds on the the correct way and your problems will be gone!!
#6440
#6441
Pics as promised
All authentic Tamiya parts except screws (fastener-express) and turnbuckles (tech racing.) I've noticed Tamiya parts fit perfect compared to aftermarket parts, only downfall is price, but "you get what you payed for." I honestly could of bought a TRF equivalent chassis, however, installing part for part was a fun process. Also, a too light chassis takes a big toll in ABS tire drifting.
Car is almost done - all I need is suspension blocks and electronics. By next week the Mamba Max will be dropped in.
Thanks to all the people who helped me decide on parts to get (and not to get )
#6442
#6443
nice
nice ride Gerok. For a change i'm leaving my TA-05 bone stock, it's a great car out of the box. BTW, i solved my steering problem, the problem was part K7, the right steering arm, which i installed upside down...in my defense, the part looks almost exactly the same either face up. thanks for your help.
got the new 10 spoke Tamiya chromes, looks great with the silver springs on the stock kit.
#6444
gerok, you need the lightweight carbon chassis
#6445
Originally Posted by tc3team
#6446
My wallet is recovering from a major weight loss. I might consider the carbon chassis after I eat up the plastic one....
#6447
hi, i have an extra new in package aluminum diff joint #53919 for 22 shipped.. sorry for the ad..
#6448
hi,guys i have a TA05.I just want to know the normal setting for this car.(downstop,ride height,.....etc).thks
#6449
Ride hieght and springs
So I've had my TA05 out for two races now, this last one I put the carbon fibre shock tower on the front, but I could not get my ride height down to 5mm which is what it was set at before. I have the TRF shocks and am using the associated brass springs. I ended up running at 6mm and did fine, but it rotated better at the 5mm setting. Anybody else have this problem, I know others are using the carbon fibre towers and running 5mm so can you snip a little off the spring or do I have something messed up. Any help would be great. Thanks.
#6450
Get this:
http://www.tamiyausa.com/product/ite...oduct-id=53876
This would lower your spring 1mm downward, in short, shorten entire damper 1mm. This should give you 5mm ridehight. Or you can get Tamiya short spring, but I prefer 1mm downward spring holder to be solution.
