Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 06-30-2007, 02:48 PM
  #7936
Myker*'s Avatar
waiting on my s9550.. and other things
Myker* is offline
Old 06-30-2007, 02:52 PM
  #7937
Originally Posted by bukil
I use 35-37 tooth pinion with my 104 tooth spur for my CO27.
But what pitch is the pinion? Arent pitch and teeth seperate things?
Frost99999 is offline
Old 06-30-2007, 02:58 PM
  #7938
Myker*'s Avatar
tamiya spur pitch is called ".04" i think. Edited: .04 is 64 metric, sorry for the confusion.
Myker* is offline
Old 06-30-2007, 02:59 PM
  #7939
rctouringracer's Avatar
Pinion pitch should be 64 metric.
rctouringracer is offline
Old 06-30-2007, 07:46 PM
  #7940
Jam-ehz's Avatar
Yeah, it seems the Japanese call it by .04 or .06 for 64 and 48p metric respectively, but in North America we just refer it to "48 metric" or "64 metric", or at least that's what I've seen Robinson list theirs as..
Jam-ehz is offline
Old 06-30-2007, 09:43 PM
  #7941
Blue_VB_SL253's Avatar
Originally Posted by Jam-ehz
You'll always want negative toe (toe out) for the front, or at the very most no toe. Most do 1 degree or so out.
64 pitch is more efficient, a bit less noisy, and gives you more options when it comes to gearing, but is more prone to debris getting in the way of the meshing since it uses smaller teeth. I myself have no problems runnning 64p outdoors, but some will prefer the 48p.
Thanks heeps mate, I changed from toe out to to in because ive been struggling with mmy steering. Ill see what works better, as today i got my self a alloy servo saver.
Blue_VB_SL253 is offline
Old 06-30-2007, 10:15 PM
  #7942
macnkitty2002's Avatar
TA-05R is on the way, should be on my doorstep Tuesday or Wednesday. Hope I've made a good decision with this car. My buddy might let me use his new Novak Velocity 4.5 brushless system too, but maybe not. Any suggestions as to what electronics I should get if I'll be running mostly club parking lot races and occasionally carpet? Also, if you have any other build tips, etc. to share they would be greatly appreciated. Thanks guys, I'm glad to finally be an owner of a Tamiya kit.
Mac
macnkitty2002 is offline
Old 06-30-2007, 11:57 PM
  #7943
13Zulu's Avatar
Default TA-05 Gearing
Hi, Just built my TA-05R and used it for the first time.. awesome, and comes out feeling lighter than my TA-05 although I did use a titanium screw set as well.
I stuck a 540 sports motor in my TA-05 and 29 pinion and 67 Spur which comes out at about 5.2:1 ratio and burnt the motor out quick smart, any clues on gearing as the 540 pro guys just use a silver can and I am sure that their ratios are in the low 4's, so would be drawing a lot more current? or perhaps I just got a dud motor?
13Zulu is offline
Old 07-01-2007, 01:44 AM
  #7944
Hey guys, another question. Does any one use Robinson racing spurs and pinions in there TA-05. If so, what spur sice are you running for 64 pitch gearing
Cheers justin
Old 07-01-2007, 01:54 AM
  #7945
birdy's Avatar
what advantages and disadvantages would there be to swapping my 3 racing chassis back to the tub chassis
thanks
birdy
birdy is offline
Old 07-01-2007, 02:01 AM
  #7946
totaly incorrect, although they are very VERY similar, Tamiya supply .4module pitch gears with the TA05R, which is obviosly METRIC. 64dp is an imperial measurement, they are not they same, not to be confused as the same either. You run either one or the other, never a mix.
DA_cookie_monst is offline
Old 07-01-2007, 02:02 AM
  #7947
thanks
birdy
Well, on the plus side, you get a little more compliant chassis and stone protection.
on the negative, you get less space for electrics, heavier, less precise on the track.
Old 07-01-2007, 02:05 AM
  #7948
Double Quattro's Avatar
thanks
birdy
Advantage: TCS legal
Disadvantage: More weight, tweak issue, less space for electronics
Depending on your racing surface, the tub may also offer the advantage of additional flex.
Hope this answers your question
Double Quattro is offline
Old 07-01-2007, 02:15 AM
  #7949
birdy's Avatar
thanks for the fast replys
i race on polished wood floor and outdoor asphalt so would the extra flex help or not
thanks
birdy
birdy is offline
Old 07-01-2007, 02:38 AM
  #7950
sosidge's Avatar
I run the R on polished floor and occasionally on tarmac and yes, the tub does make the car a lot more settled and easier to drive, I wouldn't say it was any quicker than a double deck car but it does require less attention.
sosidge is offline
