Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 04-18-2007, 05:34 PM
  #7186
The TA05IFS would be tempting just for running the EBBRO 350R.
A-Ko is offline
Old 04-18-2007, 06:33 PM
  #7187
Originally Posted by Core Creations
I would think thye would be very close to the anniversary edition.
No, it won't be, the holes do not match standard TA05.
trf_racer is offline
Old 04-18-2007, 09:06 PM
  #7188
Trader Rating: 42 (100%+)
Originally Posted by Nexus
Is there anyone who just sells this as a kit instead of piecing the screws together?
Anyone know?
Nexus is offline
Old 04-18-2007, 09:12 PM
  #7189
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
So Tamiya are bringing out all the hop ups that 3 Racing made a year or so ago??
Nice bling, but from what I have seen, I doubt there'd be many real performance gains to be had.
That inboard suspension is intriguing though!
I also notice the MS has the provision for the MSXX Motor Air Duct!
nexxus is offline
Old 04-19-2007, 01:42 AM
  #7190
rampal's Avatar
Anyone know?
rc champ
rampal is offline
Old 04-19-2007, 02:34 AM
  #7191
over gear's Avatar
Trader Rating: 18 (100%+)
is it just me?? are all the graphite tub chassis tweaked even in brand new condition? the rear right side of my chassis lifted up quite a bit.
how do you untweak a car that is tweaked to begin with?
over gear is offline
Old 04-19-2007, 02:40 AM
  #7192
dodo's Avatar
from what i know most of the tamiya graphite tub chassis tweaked. maybe sort of defective mould? if the tweak is not so bad we can compensate it with droop.
perhaps it's the reason why tamiya didn't include it with TA05R?
dodo is offline
Old 04-19-2007, 02:45 AM
  #7193
sosidge's Avatar
On the subject of chassis "tweak", my TA05-R's plastic chassis seems to be a little bent up at the front? Only one race meeting on it, I wonder whether is the result of impacts (I didn't actually crash though), or something about the mould?
The centre section and rear of the chassis are not tweaked at all.
sosidge is offline
Old 04-19-2007, 03:59 AM
  #7194
I have 4 TA05 tub chassis, 2 plastic and 2 carbon reinforced. All of them are mildly tweaked(about .5 mm) from day one. I believe that it is a problem with the mold, in particular where the battery cutouts are. This area needs to be reinforced. With that said, I have learned to live with this mild tweak by putting downward pressure on the tub on a flat surface and tightening the front and rear braces in an X pattern. I generally do this after each race day unless there were any hard crashes.
Pete
Pete Thomas is offline
Old 04-19-2007, 04:31 AM
  #7195
are ta05's suitable for the novak velociti 3.5r brushless motor or does it require hop up parts?
andy147 is offline
Old 04-19-2007, 04:35 AM
  #7196
Hop-up parts are recommended.
You might want to have aluminum diff joint so your drivetrain can withstand the power.
Old 04-19-2007, 04:41 AM
  #7197
53990 TA05 Aluminum Bulkhead will be released in June, selling for 6000yen.
Old 04-19-2007, 05:06 AM
  #7198
sosidge's Avatar
Anyone ever tried boiling the tubs to "release" the tweak? Any success?
The Tamiya mould itself is most likely spot on, it is the different rates of cooling after the injection moulding process that will result in small tweaks on a large component like this.
sosidge is offline
Old 04-19-2007, 05:40 AM
  #7199
Wolf's Avatar
Well, this is still a design/manufacturing defect. How come they do not take the shrinking of plastic into account ?!
Wolf is offline
Old 04-19-2007, 05:41 AM
  #7200
Regional Moderator
Darkseid's Avatar
TO ALL THE PEOPLE NOW DISCUSSING TWEAK...
This is not a new issue. This same discussion happened quite a while ago when the graphite composite chassis first came out. You would have thought the sky was falling the way some people were acting..."oh...goodness NO...its tweaked...damned Tamiya...I'm selling this chassis and getting a graphite plate chassis...oh...the horror!"
Its not a problem with the mold, its just the way its going to be. I've heard that both Tamiya and Associated(who have been doing the graphite molded tub a lot longer) say that there's pretty much NO WAY to mould those chassis, have them cool, and still not have one bit of tweak in them. According to them, it just can't be done. And from what I could tell, all the efforts to un-tweak them have had a only moderate effect or none at all.
So just compensate for the tweak with droop and move on. Read back on the thread. Not one person here who was already fast with the car, lost anything due to this mild tweak. Thats one of the advantages of a car that isn't built up stiff as a brick. A mild tweak doesn't leave you scratching your head all night and still lets you set up the car around it and go just as fast.
Darkseid is offline
