Tamiya TA05 Touring Sedan
#3586
Originally Posted by TAMIYAMANUK
hi guys
you have probley heard this a million times
what is a good pinion and spur (64dp)to use on a tight track with a big straight got have good out accerlation out of the corners and good top speed
any help plzzz
kind regards
TAMIYAMANUK
any help plzzz
kind regards
TAMIYAMANUK
#3587
Originally Posted by danjoy25
Im actually thinking of getting one aswell as I read that its around 40 grams lighter, but not sure now as others are complaining about tweak.
Does anyone know what weight difference you can get with the Tamiya Titanium Axles in all four corner?
Can anyone also confirm that the Tech Racing Blue turnbuckle set and Carbon Battery holder and the same as what tamiya is selling?
#3591
Regional Moderator
Originally Posted by Scarab
It is exactly 10 grams lighter. That's it. It IS, however, far stiffer and has greater rigidity.
Scarab
Scarab
Maybe my memory is playing tricks on me.
Can anyone else confirm what the weight difference is?
#3592
Originally Posted by Darkseid
Thats odd, I could have sworn that when I weighed my old and new chassis, that the difference was much more than 10 grams.
#3593
Lt wt. chassis
I'm getting out 15 grams lighter but I put ti screws on the bottom and left off the battery mount! It drives more like a 415 with the new chassis. Rigid and not as much flex in the corners. Although I noticed that if you put the tires too high up the burm it will flip over. I didn't remember it doing that before?
I wonder if putting sway bars will help or hinder this condition?
#3594
TRF fluorine coated damper set
Hi all:
I've been reading all this thread and it's amazing how many things you can learn around here!!!! Anyway, I've just bought the TRF damper set (the titanium one) and when putting it together, I just realize the existence of a black o'ring underneath the piston.... also that in the instructions that for the TRF414 you don't need to use it, but for TB01 you use 1 or things like that. I'm trying to use the TA05 for racing outside on cement, so do I need to use it or not? Does anyone of you use the o'ring either indoors or outdoors?
Thanks a lot,
Thanks a lot,
#3595
Hi,
The black O ring is, as far as I am aware of, used to shorten the stroke of the piston. The space between the lower suspension arm and the shocktower are different for every Tamiya model. For example TRF414 has an higher shocktower than the TA04 TRF model. Beside when driving a 415 with the kit shocks it has longer pistonrods then when useing the MS versions .........
Guys correct me if I am wrong.
Marc
Marc
#3596
Hi TDO:
Yeah, I'm aware of using the o'ring to shortened the overall length of the damper. That't why I wanted to know, as there is no reference in the instructions of the damper set, if I need to use it or not (or use 2) on the TA05....
Thanks a lot, this thread is really fast!!!
#3597
Was checking out the aluminum clamp hex hubs and see they have 4mm,5mm, and 6mm. Which ones should I pick up? I will be running mostly at The Colliseum @ Frederick Hobbytown. Thanks.
#3598
Originally Posted by rampal
Hi TDO:
#3599
Originally Posted by TDO
Hi,
Marc
Marc
#3600
Regional Moderator
1.If you run foams, it will give you enough clearance so that 28mm foams wont drag on your front camber ball cup.(Depending on what company's foams you use, you may still have to shave a little off the ball cup)
2. It widens the car to give more stability and keeps you from having the stock axles sticking out so far from the wheel nut. Axles that stick out too far can cause breakage if they catch a board or something.
The only downside to the 6mm hexes is that for some reason, Tamiya decided to clear anodize them and leave them natural aluminum color, instead of anodizing them blue.
