Tamiya TA05 Touring Sedan
#2086
Tom,
I had the exact same, very frustrating, issue. A little bit of pressure on the nut-side should be sufficient to get the screw to bite. Because I had some issues with the nut loosening, I acutally ended up flipping the nut upside down in the little plastic mount, just to get the nyloc part to grip first.
Good luck,
dave.
Good luck,
dave.
Originally Posted by mild seven
i have a problem with building the Diff for the 05. basically it seems like the long screw that goes through the diff is to short and does not quite reach the lock nut. im pretty sure ive built the rest fine as ive built Tamiya diffs alot and they are pretty much the same.
Just wondering if anyone has had this problem or has a solution to it.
Thanks Tom
Thanks Tom
#2087
Originally Posted by madjack
alright...alright, here you go
Nice car, BTW what kind of susp. block did you use? I mean what letters?
#2089
I'm running the following blocks:
front blocks 1X/1XD (f/r)
rear blocks 1XC/1B (f/r)
don't know much about this blocks, will they increase toe? or are they the same as the stock ones just more BLING?
Tnx
#2090
Tnx
Tnx
with madjack's setting he has 2 degrees of front toe out and 2.5 deg of rear toe in (plus the built in toe for his rear uprights (probably using 0 deg hubs though.)
madjack's block set up is based on satoshi's set up in the RCWorld mag.
#2091
Originally Posted by Hebiki
yes, using a different combination of blocks in the front (toe out) and the rear (toe in) will yield different toe angles. they are more durable than the plastic ones. the aluminum blocks are stronger and probably weighs about the same.
#2092
#2094
Here is a link to Tryhard's site. Look under the excel sheets, he has one with all the block widths and the combinations. TryHard's site
#2095
#2096
46mm Universal Problems
I just try putting my 46mm universals on in the rear and I have
ran into a slight lil prob. if you see the picture up here that I included
,you can see the axle doesn't come out far enough so that I can
stick the pin through the hole on the axle...
And I'm pretty much running stock everything, so can some please help me.
Also what size are those blue turnbuckles everyone is using for the upper
suspension arms that replace the 3 x 28 on TA-05?
#2097
Did you use the wrong wheel axle?
#2099
Originally Posted by Difuser
Can't quite tell form the pics but it looks like you have the LW outer axle shaft in the STD suspension hub. The easy way to tell is the LW has a rounded carrier for the CVD whereas the the STD axle has a more squared off profile.
#2100
Does anybody know were i can get the TRF blue shock set pictured above and also the blue screw kit, Part no's please...... Cheer's boy's
