Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 09-21-2005, 01:01 PM
  #1336
Jam-ehz's Avatar
Originally Posted by maxepower
Was that blue belts for TA05 or was the picture or were they white and with all the blue bling on the TRFMS-TA05 the belts looked blue.
It seems that the belts are actually blue, according to the caption... extra bling indeed..
To answer my own question, those three-hole carbon pieces are spacers for the damper towers, as well as those blue washers being more spacers for the ball cups..
Which asks the question.. of course, the holes along the shock tower affect how much strength the shock has over the suspension... But what does moving the top shocks ends lengthwise along the chassis do that the towers wouldn't?
Apparently the spring retainers will "Lower your center of gravity by 1mm", and the carbon battery plate will save 5.4g of weight with its aluminum screws and such..
Tamiya USA has all those parts in their Coming Soon list already, but not the chassis..
Jam-ehz is offline
Old 09-21-2005, 01:47 PM
  #1337
Kevin CBR's Avatar
Originally Posted by rayhuang
I am so amazed at the decals that come with these bodies. Heres the body I just got form JayBee on the TA05. Sorry about the body posts , but I dont want to cut them tiill I try a bunch of different bodies on the car.
Ray
Interesting you got that body with a TA05. That is the Avex Dome Mugen NSX that came out with the TA03-R kits. Haven't seen them in a while, at least in that good of shape.
Kevin CBR is offline
Old 09-21-2005, 01:49 PM
  #1338
rayhuang's Avatar
yeah-sucks that I stickered it-Now I dont want to use it!! I also got the Ferrari body with the car.
rayhuang is offline
Old 09-21-2005, 02:03 PM
  #1339
Jam-ehz's Avatar
What's the consensus on the F430 body? Is it better than the Skyline or the NSX?
Jam-ehz is offline
Old 09-21-2005, 02:22 PM
  #1340
Hebiki's Avatar
Trader Rating: 26 (100%+)
its a very long body. i still prefer the old ferrari body. the 03 NSX is good. i like the '04 NSX better with the hopup wing never used a skyline before.
05 NSX is looking really good too along with the Audi A4 DTM body and ESSO Supra body
Hebiki is offline
Old 09-21-2005, 05:57 PM
  #1341
Core Creations's Avatar
Trader Rating: 108 (100%+)
Any idea on availability on the MS TA05?
Core Creations is offline
Old 09-21-2005, 06:41 PM
  #1342
maxepower's Avatar
Talking
[QUOTE=Jam-ehz]It seems that the belts are actually blue, according to the caption... extra bling indeed..
When you change shock towers they are narrower than the plastic ones so if you don't add the spacers the shocks are going to lean back a little towards the rear of the chassis so to correct this you add spacers to keep the shocks perpendicular to the chassis or parallel to the shock tower! Hope I answered your question.
maxepower is offline
Old 09-21-2005, 07:47 PM
  #1343
ttso's Avatar
Spool, as Difuser said, is good on corner entry and exit, bad on mid-corner. However, as personal experience, spool also work better with modify motor than stock motor. IMO it's because spool need extra driving power to make it really work. So if you doing stock racing, it might not as good as modify to do spool.
Also, the driving characteristic is bit different with spool. If you get the driving right, spool's corner entry and exit is just amazing.
ttso is offline
Old 09-21-2005, 09:32 PM
  #1344
buboy28's Avatar
might be the same release as the TRF-415MSX
buboy28 is offline
Old 09-22-2005, 11:58 AM
  #1345
Regional Moderator
Darkseid's Avatar
Well around when is that?
Darkseid is offline
Old 09-22-2005, 12:04 PM
  #1346
December is what I heard on the 415MX
Old 09-22-2005, 12:07 PM
  #1347
Regional Moderator
Darkseid's Avatar
Civic: Don't know if I can wait that long for the TA05 MS!
You know after our experience with the Losi, I'm not up for waiting for kits anymore!
I may just go with that first option we were looking at.
Darkseid is offline
Old 09-22-2005, 12:08 PM
  #1348
Tell me about it!
  #1349
I'll be ready Sept. 29th!!
Old 09-22-2005, 12:10 PM
  #1350
Regional Moderator
Darkseid's Avatar
Sounds good to me.
Darkseid is offline
