Hot Bodies Cyclone
#9616
anyone know if an 88t spur will still mesh properly or do i need the brushless motor mounts?
#9617
#9618
I need a good starting set-up..... stock/rubber/asphalt.
I live in the SoCal area, and will mostly being racing at SoCal and/or other parking lot club races.
THANX !
THANX !
#9619
#9622
thanks!
#9623
Yea have defected welll nearly as I have a Clonosi now Just finished the drive-shaft change (9616 & 7) and there is no chatter whatsoever I noticed that the hubs on the Losi R were a tad longer 1mm in total than the Clone, but then the hex is 1mm narrower so is the same geometry. I have also drilled a hole in between the original holes the longer arm on the Losi 'R' hub carrier to bring the steering arms back in line, and took a little material from the inside of the caster blocks, so as to not let the heatshrink tubbing on the U,J, joint rub on the caster. Here are some pics of th finished project and will be running it tomorrow night
Cheers Malc
#9624
and some more
Malc
Malc
#9625
Whats the smallest pinion, and the biggest pinion I can fit in the stock motor mount?????
I need to get a 4.6 FDR, so I would like something that will mesh with a 47 tooth pinon, but I dont think that will work
But I can/will dremel the stock mount if needed
#9626
I just updated my blog with a few pics showing my latest mods.
I just won the latest national race, pretty easily too, so I am very pleased.
http://jdracing.blogs.se/
#9627
ended up using a 73s x 38p all fits stock mount,,,and i thought the 38p was a dinner plate.... but a 47p PHOOR thats big!
Now to try out my new spektrum elec telementry pack... to watch my temp...
anyone else already using one ?????results????
PS. very nice John D,,,,but you lost a cell
#9628
Cool!
#9629
AWSOME!! Thanks!
So a 89 tooth spur and a 47 tooth pinion will give me 4.62, and thats where I want it
That will mesh for shure?
Thanks guys!
#9630
Cool!
im using 72T spur and 36 T pinion giving me 4.67
