Hot Bodies Cyclone
#8118
Gday all
Just wanting to compile a list of the best CYCLONE parts and suppliers...
and in the process build the ultimate cyclone....
Add 1.
Andy moore cycone
2. GTB-novak 5.5 (rc mart)
3.ver.2 steel drive shafts, or maybe, (team almighty) titanimum cvds?(dinball)
4. ali rear hubs
5. ali c hub carrryers
6. ali fnt knuckels
Im sure there will be plenty of different views but that will only make it better.
horses for courses, carpet and asphalt
any constructive input welcome
above is what i have to start with in my transporter,, there must be plenty more others have comeacross..
Add 1.
Andy moore cycone
4. ali rear hubs
6. ali fnt knuckels
#8119
Right, there went the third diff screw...this is getting annoying.
Thinking about doing something drastic now, like drilling the diff screw hole from 2mm to 2,5mm and stick a schumacher hardened diff screw and nut in there. I know they last!
#8120
Originally Posted by ROV
Gday all
Perhaps building the Ultimate Cyclone Driver would be a better idea.
#8121
Drill both halves out to 2.5mm and just the standard screw. When the diff is run the screw bends slightly and when it hits the side it snaps. You will probably notice marking on the old screw when this happens. Also dont over lubricate the diff and do the final tightening of the diff in the car this makes sure that it is not overtightened.
#8122
#8123
Diff screws i've had no problem SINCE
put extra washer on spring side,,so bolt, washer, balls,washer, spring, washer,washer
blk z203
dont use black z 203 use a steel washer,,,lets spring slip on the washers not hub..
Also someone posted a thread that was HARA assemble in chinese,but the photo showed him putting a 1mm purple shim washer on the brass plastic nut side..of diff.
seems to me that the spring in some is not flat top & bottom you can see the bolt angle when you tighten
Good luck ive seen guys at the track pull hair out with 3 laps to go...
Sounds like 2-bad is on it....
blk z203
#8124
is assembly on the newer narrow diff pulleys different to the older wide pulleys from the black kit?
i tried buidling up my diff with the older pulley but couldn't get it as nice as i could with the wide pulley so i just went back to the wide one. Is theres something different about the ball sizes or anything?
el
el
#8125
el
el
Andy moore told me he prefers the old wide diff pulley, as he explained it the old pulley has square holes and tends to hold the diff grease longer.
Also i noticed that the diff balls run on a slightly wider circumference, so should run a bit smoother with less pressure. Downside is though, the holes do seem to wear faster than the narrow one.
#8128
ok
#8130
Purple pivot blocks for the Cyclone
Good evening guys,
Just a quick question, does anyone no the part number for the Hot Bodies Cyclone Pivot Block Set in purple. I can find the Blue and Black sets on Speed techs site but not the purple ones.
Regards Dave Rand
Regards Dave Rand
