Hot Bodies Cyclone
#616
I must say I prefer the black as well - one reason I bought the original gearbox RS4 (over the TA01 and YR-4) was because of the black hardware, chassis plates and plastic.
#618
Originally Posted by ATXPro4
I have had friend that have had the origonal color removed, and had parts reanidosed another color, i dont know what kind of metal shop could do it but they said it costs about $50.00
your local anodizers can usually do... I had a Blue Pro3 at one time.
#619
Originally Posted by Frank McKinney
I believe the new Pro 4 shocks will be included in the Cyclone kit.
#620
Originally Posted by axel
will it be black as well? will anything of the car be black?
it still not sure yet but if you have a look in Aug Rc driver magazine the whole car totally black. but hpi web was showing that they mix with some purple stuff like titanium turnbuckle
#621
I hope the cyclone will be like another pro4, great out of the box. But still $450 is pushing it.
#623
#625
what's the biggest difference in having the belt over the upper deck instead of having it under the deck...i noticed this was the biggest change from the 415msx...and it seems to be the main choice for companies now (yokomo, hpi/hb, tamiya, corally)
#626
#627
Originally Posted by Entropy
Most likely lower CG. If you lower the upperdeck (ooo tricky grammar)... your bulkheads, steering assembly, and everything else attached it it will be lower on the chassis, not to mention less material used. Since the belt doesnt really change position on the car (only the deck moves) hence you have an overall lighter and lower CG car.
#628
Maybe as the car isnīt out yet.
#629
Hi
somebody can tell me when the Cyclone will be disponible ?
Thank you
Bye
Thank you
Bye
#630
In Switzerland it is available starting from 16.08 (the first supply)
