Hot Bodies Cyclone
#646
I'd imagine that purple or black strapping tape can be purchased wherever you find the Cyclone for sale
Hara doesn't like battery straps, so I believe strapping tape will be recommmended. I'm sure some industrious fellow out there will make some black-anodized CNC aluminum standoffs and a graphite battery strap as a non-factory option though!
#647
Originally Posted by axel
Just curious everyone...why did we all make up our minds to buy this car already when it is still in the R&D stage? It's not like this kit is going to be cheap anyways? HB has to be pretty thankful of having Hara, Surikarn, and Moore proving that HB's first major tourer is a winner.
#648
i know it's been said about the cyclone's final production, but i guess this is confirmation
http://www.hotbodiesonline.net/cyclone.html
#651
was about to say the exact same thing. look like standard hpi super shocks.
#652
Because the tops and bottoms are anodized black, it is hard to see some of the detail, as mentioned above. But the shock bodies look like the new HPI shocks, not the older Proceed shocks (look at the color of the anodizing). The Cyclone shock caps don't look like they have the hex shape to them, true, but that won't affect the performance of the shocks. The bottoms of the shocks are hard to see so can't comment about them. I'll ask around
#653
Originally Posted by John Doucakis
I highly doubt it has the new shocks as the cylinder cap of the black shocks on the Cyclone are round, where as the new HPI shocks have a squarish cylinder cap:
#655
before and after
just one question...what was the meaning of changing that flat aluminum piece on the upper deck to a rounder one?
#657
That can be, but isn't it so that the rounded version will bend easier than a straight one, since the straight version will let the energie/stress flow better through it?!
That's what I think, but that doesn't make sense, because they changed it...
#658
That's what I think, but that doesn't make sense why they changed it...
#659
Maybe I know why they did it.
When you look at the early prototype with the straight bulkhead, you can see that it's a bit fragile (above the rear 2 battery cells). A lot of people saw that, so maybe that's why they changed it to a rounded version.
So it can absorb the energie (like in a crash) and bend a little (and back to the orginal position) instead of breaking the whole bulkhead (with the straight version).
That's the only reason I can think of why they changed it, but yes... that does sound a bit odd. Maybe someone else can come up with a better story why they changed it.
#660
a reason could be. having your fingers and a socket driver in the slock above will be tight. so from the side, the arch will give more room for your fingers to grab the pinion.
