Hot Bodies Cyclone
#766
Originally Posted by AdrianM
I have to chime in here because you guys are way off. Kevlar reinforced belts are NOT like rubber bands. They can stretch a minuscule amount under load but you are talking 10ths of a percent. Belts are faster because once they are moving the are more efficient than shaft systems. Also please note that the shaft itself has only a small amount to do to with the properties of a shaft car. We are really talking about the properties of bevel gears. Under high loads gears are good but the gear lash in the system starts to fight you at high speed and causes some really odd harmonics in the drive train. This slows shaft cars at high speed.
That said you are talking really small differences here. On any day any car can win if it has a good setup and a good driver at the wheel. But in controlled testing belts are faster and more efficient
Give Hara some credit here. Don't you think he has done back to back testing? I haven't asked him but I am pretty sure he has. What car is he running now...end of discussion...lol!
If anything from the Hara car switch we should note............. a driver can be fast with BOTH designs.
Jeff
#767
yes mostly what i was getting at about a shaft car was its torque and how its prone to torque steer that is why its not a popular in running mod. not saying it cant by any means. i love shaft cars, that is all i have ever owned. a driver like the Assoc. guys have always driven a shatf car so they know how to compensate. also they are Pros so they have more skill and better throttle control then a driver like myself, and because i am not as skilled i struggle a bit more from the torque of a shaft car in fast classes.
#768
I personally prefer belt over shaft, but still like both. I just find belt to handle more consistant. I was faster with my xray then I ever was on my pro4.
#769
Jeff
#770
correction.. he AIDED in the design of both cars, through race testing. you're undermining the efforts of hpi's engineers making a statement like that.
..he designed both cars ..
#771
It comes down to this...... driver, driver.... driver!!!
Originally Posted by Jeff Brown
That is fine if Hara is now running a belt car.......... but a SHAFT car won the Reedy Race. I don't think either design has an advantage after racing a TC3 for 4 years and switching over to belts myself. In the end......... all cars have 4 arms and a drivetrain. The percentage differences are not enough to take into consideration.
Jeff
Jeff
#772
The old Belt vs shaft debate hehehe
What is it they say, the noisey it is the less efficient it becomes..
With that in mind then the belt drive would be more efficient over the shaft, (obviously there are other factors)
Im reckoning theres not a great deal difference between the cyclone and the pro4 its going to come down to setup at the end of the day and how quick a driver you are, would be nice to try back to back the cyclone and pro4 with the same setup just to see, any chance HB would let us do that, try before you buy sceme !!
Who knows?? i say if youve got the money go 4 it if you havent dont worry keep the pro4
#773
Does anyone know what online shops are offering a pre-order at the moment and the cost they are listing for the kit?
#775
do people think it is worth pre-ordering or will the price drop quite a bit after a month or so?
#777
does anyone know if the cyclone comes with delrin pivot balls for the blocks or does it come withteh metal ones like the pro4
you know how it works...they want you to buy a ton of option parts....
for the same price I prefer the Square Delrin pivot balls..they're black. the white one don't look as nice after they get dirty...
#779
I think they'll be plastic as the cyclone uses the same plastic shock parts set as the Pro 4 which the plastic ones come on.
It's not a problem though because I'm going to use my purple ones off the Pro 4 on my Cyclone and I'm sure a few other people will do this.
