Hot Bodies Cyclone
#781
Well the release can't be that far away for us in the UK as Mirage Racing, the UK distributor are now listing it on their site under the products I've been told that we should expect a release date of early September. Also, the RRP has dropped from £399.99 to £374.99, so it's all good.
Does anyone know if the UK and Europe versions will come with CVD's instead of universal drive shafts like the Pro 4?
#782
I don't understand wat is this:
HB70732 MIDDLE CHASSIS WOVEN GRAPHITE - CYCLONE
Make : Hot Bodies
Type : Car Spares & Options
Range: Chassis £ 7.99
Make : Hot Bodies
#783
It's probably the piece of carbon fibre which braces the rear bulkhead and motor mount...
#784
Release date pushed back?
Has anyone heard anything about the release date of this car being pushed back and the shared parts list being shortened to less than ten parts?
I was at my LHS yesterday and the store manager told me that he had received information from his supplier that HB was going to change several parts, including the arms and hubs. Nobody else seems to have made mention of anything like this though.
#785
so far from what I see...same suspension components..
#786
I haven't heard anything, and I certainly hope those rumors aren't true as the compatibility between the Cyclone and the Pro 4 is one of the reasons for me wanting the Cyclone and not something else.
#787
I'm not trying to start a rumor. The guy said that he had seen an updated list (which I couldn't find anywhere) of the parts that crossed to the Pro 4 and it was less than ten things. What he may have seen was HB's parts list which may have HB part numbers assigned to the same HPI parts. I was just curious if I had missed a post about a change in the shared parts. I agree with you guys as I've got a ton of Pro 4 parts and that is a big reason why I want this car.
#788
so far this is all the HPI parts that's being used:
Existing Parts:
6274 1 PRECUT FOAM BUMPER GRAY (RS4)
6543 2 RACING SHOCK SPRING 14x25x1.5mm 6.5COILS(SIL/2pcs)
6820 8 SILICONE O-RING P-3 (CLEAR/8pcs)
6888 1 PRO SHOCK SILICONE OIL #50
7114 1 TRANSPONDER HOLDER
72105 2 DIFF RING D CUT TYPE (2pcs/ FOR GRAPHITE DIFF HUB)
72111 10 SHIM SET 3x5mm (M3x5x0.1-0.2-0.3mm/10pcs each)
72302 4 BALL SET FOR SWAY BAR
73506 1 CARBON GRAPHITE SUSPENSION ARM SET
73507 1 CARBON GRAPHITE BLOCK AND HUB SET
73508 1 STEERING PARTS SET
73510 1 SHOCK PARTS/BALL END SET
73513 1 BUMPER/BODY POST SET
73518 1 CARBON GRAPHITE C HUB SET (4 DEGREES)
73522 1 DIFFERENTIAL SCREW AND HEAVY-DUTY NUT (2mm) SET
73523 4 BLADDER 12x3.5mm (FLAT TYPE/4pcs)
75106 20 BODY CLIP (6mm/BLACK/20pcs)
75115 4 BALL STUD 4.3x10.3mm (2mm SOCKET/4pcs)
75116 4 BALL STUD 4.3x13mm (2mm SOCKET/4pcs)
75119 2 SUSPENSION SHAFT 2.5x24.5mm (2pcs)
75121 4 PIVOT BALL 3x5mm (4pcs)
75122 4 STEERING BLOCK BUSHING (4pcs)
75129 5 REBOUND FOAM (5pcs)
75143 1 SERVO SAVER SET
75144 1 PIVOT BLOCK SPACER SET
75161 1 PIVOT BLOCK (2.5 DEGREES/ALUMINUM/PURPLE)
75162 1 PIVOT BLOCK (3 DEGREES/ALUMINUM/PURPLE)
75187 2 UNIVERSAL AXLE
75188 2 UNIVERSAL REBUILT KIT
76600 1 SPUR GEAR 100 TOOTH (DELRIN/64PITCH)
93462 2 TITANIUM TURNBUCKLE M3x24mm (2pcs/PURPLE)
93467 2 TITANIUM TURNBUCKLE M3x34mm (2pcs)
A150 12 BALL 2mm (12pcs)
A157 12 CARBIDE DIFFERENTIAL BALLS (3/32 in./2.4mm/12pcs)
A165 2 SPRING 6x7x1.5mm (DIFFERENTIAL) BLACK (2pcs)
A166 2 DIFF THRUST WASHER 2.2x6mm (2pcs)
A302 8 HEAVY-DUTY BALL CUP 4.3x18mm (8pcs)
A495 1 39T BALL DIFFERENTIAL PULLEY (1set)
A496 1 39T BALL DIFF PULLEY FOR FRONT ONE-WAY (A906)
B012 2 BALL BEARING 3x6x2.5mm (FLANGED/2pcs)
B015 2 BALL BEARING 4x7x2.5mm (2pcs)
B017 2 BALL BEARING 4x8x3mm (2pcs)
B020 2 BALL BEARING 5x8x2.5mm (2pcs)
B021 2 BALL BEARING 5x10x4mm (2pcs)
B030 2 BALL BEARING 10x15x4mm (2pcs)
Z082 10 FLAT HEAD SCREW M3x8mm (HEX SOCKET/10pcs)
Z083 10 FLAT HEAD SCREW M3x10mm (HEX SOCKET/10pcs)
Z150 1 ANTENNA PIPE SET
Z155 1 DIFFERENTIAL LUBE (SILICONE)
Z156 1 GRAY DIFFERENTIAL LUBE (FOR DIFF SMALL BALLS)
Z203 10 WASHER M3x6mm (10pcs)
Z234 10 CAP HEAD SCREW M2x5mm (10pcs)
Z242 20 E CLIP E2mm (20pcs)
Z264 10 PIN 2x10mm SILVER (10pcs)
Z350 10 BUTTON HEAD SCREW M3x5mm (HEX SOCKET/10pcs)
Z352 10 BUTTON HEAD SCREW M3x8mm (HEX SOCKET/10pcs)
Z353 10 BUTTON HEAD SCREW M3x10mm (HEX SOCKET/10pcs)
Z354 10 BUTTON HEAD SCREW M3x12mm (HEX SOCKET/10pcs)
Z355 10 BUTTON HEAD SCREW M3x15mm (HEX SOCKET/10pcs)
Z356 10 BUTTON HEAD SCREW M3x18mm (HEX SOCKET/10pcs)
Z653 6 NUT M3 (6pcs)
Z676 4 LOCK NUT M3 THIN TYPE (4pcs)
Z679 5 WHEEL NUT M4 (PURPLE/5pcs)
Z700 6 SET SCREW M3x3mm (6pcs)
Z705 6 SET SCREW M3x10mm
Z724 6 SET SCREW M4x8mm (ROUND POINT/6pcs)
Z775 6 SET SCREW TP3.2x5mm
Z814 10 ALUMINUM WASHER 3x6x0.75mm (PURPLE/10pcs)
Z817 10 ALUMINUM WASHER 3x6x2.0mm (PURPLE/10pcs)
Z852 10 WASHER 5x7x0.2mm (10pcs)
Z857 5 ALUMINUM WASHER 5x8x1mm (BLACK/5pcs)
Z891 10 WASHER 10x12x0.1mm (COPPER/10pcs)
Z892 10 WASHER 10x12x0.2mm (10pcs)
Z901 1 ALLEN WRENCH 1.5mm
Z904 1 ALLEN WRENCH 2.0mm
Z950 1 CROSS WRENCH (SMALL)
Z960 1 TURNBUCKLE WRENCH
Existing Option Parts
6542 2 RACING SHOCK SPRING 14x25x1.4mm 6 COILS (2pcs)
6544 2 RACING SHOCK SPRING 14x25x1.5mm 6 COILS(GOLD/2pcs)
6545 2 RACING SHOCK SPRING 14x25x1.5mm 5.75 COILS (2pcs)
6546 2 RACING SHOCK SPRING 14x25x1.5mm 5.5 COILS (2pcs)
6547 2 RACING SHOCK SPRING 14x25x1.5mmx5.25 (RED/2pcs)
6548 2 RACING SHOCK SPRING 14x25x1.5mmx6.25 (PINK/2pcs)
73086 1 GRAPHITE BUMPER BRACE
75053 12 CERAMIC NITRIDE DIFFERENTIAL BALL (2.4mm/12pcs)
75151 1 PIVOT BLOCK F/R (ALUMINUM/PURPLE)
75156 1 PIVOT BLOCK 0 DEGREES (ALUMINUM/PURPLE)
75158 1 PIVOT BLOCK 1 DEGREES (ALUMINUM/PURPLE)
75159 1 PIVOT BLOCK 1.5 DEGREES (ALUMINUM/PURPLE)
75160 1 PIVOT BLOCK 2 DEGREES (ALUMINUM/PURPLE)
75172 8 DELRIN PIVOT BALL 3x5mm (8pcs)
76534 1 ALUMINUM RACING PINION GEAR 34 TOOTH (64 PITCH)
76535 1 ALUMINUM RACING PINION GEAR 35 TOOTH (64 PITCH)
76536 1 ALUMINUM RACING PINION GEAR 36 TOOTH (64 PITCH)
76537 1 ALUMINUM RACING PINION GEAR 37 TOOTH (64 PITCH)
76538 1 ALUMINUM RACING PINION GEAR 38 TOOTH (64 PITCH)
76539 1 ALUMINUM RACING PINION GEAR 39 TOOTH (64 PITCH)
76540 1 ALUMINUM RACING PINION GEAR 40 TOOTH (64 PITCH)
76541 1 ALUMINUM RACING PINION GEAR 41 TOOTH (64 PITCH)
76542 1 ALUMINUM RACING PINION GEAR 42 TOOTH (64 PITCH)
76543 1 ALUMINUM RACING PINION GEAR 43 TOOTH (64 PITCH)
76544 1 ALUMINUM RACING PINION GEAR 44 TOOTH (64 PITCH)
76545 1 ALUMINUM RACING PINION GEAR 45 TOOTH (64 PITCH)
76546 1 ALUMINUM RACING PINION GEAR 46 TOOTH (64 PITCH)
76547 1 ALUMINUM RACING PINION GEAR 47 TOOTH (64 PITCH)
76548 1 ALUMINUM RACING PINION GEAR 48 TOOTH (64 PITCH)
76549 1 ALUMINUM RACING PINION GEAR 49 TOOTH (64 PITCH)
76550 1 ALUMINUM RACING PINION GEAR 50 TOOTH (64 PITCH)
76595 1 SPUR GEAR 95 TOOTH (DELRIN/64PITCH)
76596 1 SPUR GEAR 96 TOOTH (DELRIN/64PITCH)
76597 1 SPUR GEAR 97 TOOTH (DELRIN/64PITCH)
76599 1 SPUR GEAR 99 TOOTH (DELRIN/64PITCH)
Z046 2 TITANIUM MOTOR SCREW M3x6mm (2pcs/PURPLE)
Existing Parts:
#789
and all the new HB parts:
Part Number Quantity Name
New Spare Parts
HB70700 1 FRONT BULKHEAD SET, R/L (CYCLONE)
HB70701 1 REAR BULKHEAD SET, R/L (CYCLONE)
HB70702 1 MOTOR MOUNT (CYCLONE)
HB70703 1 MIDDLE BLOCK R (CYCLONE)
HB70704 1 UPPER BULKHEAD SET (CYCLONE)
HB70705 1 BEARING HOLDER (CYCLONE)
HB70706 1 PIVOT BLOCK, FR (CYCLONE)
HB70707 1 PIVOT BLOCK, RF (CYCLONE)
HB70708 1 STEERING ARM SET (CYCLONE)
HB70709 1 FRONT ONE-WAY DIFFERENTIAL (CYCLONE)
HB70710 1 ALUMINUM CVDS BONE, 1pc (CYCLONE)
HB70711 1 SPUR GEAR HUB (CYCLONE)
HB70712 2 SHAFT 3x45mm, 2pcs (CYCLONE)
HB70713 2 ONE-WAY CUP JOINT, 2pcs (CYCLONE)
HB70714 1 CENTER SHAFT SET (CYCLONE)
HB70715 1 DIFF CUP JOINT SET (CYCLONE)
HB70716 1 ANTENNA POST (CYCLONE)
HB70717 2 SHOCK CYLINDER, BLACK, 2pcs (CYCLONE)
HB70718 2 CYLINDER UPPER CAP, BLACK, 2pcs (CYCLONE)
HB70719 2 CYLINDER LOWER CAP, BLACK, 2pcs (CYCLONE)
HB70720 2 CYLINDER NUT, BLACK, 2pcs (CYCLONE)
HB70721 2 HIGH GRADE SHOCK SHAFT, 28mm, 2pcs (CYCLONE)
HB70722 2 SHOCK PISTON (1.2), 2pcs (CYCLONE)
HB70723 2 ROD GUIDE, 2pcs (CYCLONE)
HB70724 4 SHOCK END BALL, 4pcs (CYCLONE)
HB70725 1 CENTER PULLEY, 16T (CYCLONE)
HB70726 1 CENTER ONE-WAY, 16T (CYCLONE)
HB70727 1 BELT TENSIONER SET (CYCLONE)
HB70728 1 MAIN CHASSIS WOVEN GRAPHITE (CYCLONE)
HB70729 1 UPPER CHASSIS WOVEN GRAPHITE (CYCLONE)
HB70730 1 FRONT SHOCK TOWER WOVEN GRAPHITE (CYCLONE)
HB70731 1 REAR SHOCK TOWER WOVEN GRAPHITE (CYCLONE)
HB70732 1 MIDDLE CHASSIS WOVEN GRAPHITE (CYCLONE)
HB70733 1 SPUR GEAR SUPPORT PLATE WOVEN GRAPHITE (CYCLONE)
HB70735 1 SWAY BAR 1.2mm (CYCLONE)
HB70736 1 SWAY BAR 1.4mm (CYCLONE)
HB70737 1 SWAY BAR 1.6mm (CYCLONE)
HB70738 1 BELT 170T (CYCLONE)
HB70739 1 BELT 63T (CYCLONE)
HB70740 1 LOGO DECAL (CYCLONE)
HB70741 1 SWAY BAR HOLDER (CYCLONE)
HB70742 1 ALUMINUM HEX HUB SET(CLAMP TYPE) (CYCLONE)
HB70743 1 CENTER SHAFT (DIRECT) (CYCLONE)
New Option Parts
61043 2 44mm Heavy Duty Universal Drive Shaft (Front/Steel/2pcs)
61044 2 44mm Heavy Duty Universal Drive Shaft (Rear/Steel/2pcs)
61045 1 Front Solid Axle Set (Cyclone)
New Spare Parts
New Option Parts
#791
Another Question
Since all three thicknesses of the sway bars are listed in the spare parts section rather than the option parts section does that mean they will all be included?
#792
#793
I can't believe Hot Bodies are going to charge so much for this chassis its daylight robbery in my opinion.
When ever some one makes a new chassis the most expensive part of production will be the tooling for the moulded parts, this is why new chassis cost more when they first come out, cos the manufacture wants to try and make some of this money back.
It looks like the majority of the moulded parts are from the pro4 so how do the justify it costing so much !!!!!
All I can think of is they know they can get away with charging so much because people have to have the latest product at any cost
#794
No Joke. $470 bills!
Looks like I will pass. I don't care how competetive this thing is.
I thought I was dumb when I got my FK05 for $370.
Unproven as of yet parts support, First electric tourer, nothing innovative about it and yet more expensive than Tamiya out of the block?!?
I don't care if it was made in conjunction with HPI. I'm a huge HPI fan but I wouldn't pay that much even for a Pro 5!
Sorry HB, unless this initial price is wrong, I'm out.
