Like Tree1Likes
Xray T1FK05
Old 04-13-2005, 01:58 PM
  #1726
tboned_2002's Avatar
what class will you be racing, I see that your racing on carpet. look on the rcamerica's website for Raph and Mikes setups form the carpet nats, Id try to get as close as possible to their setups with regards to spring rates.
tboned_2002 is offline
Old 04-13-2005, 02:00 PM
  #1727
rctoyguy's Avatar
Trader Rating: 21 (100%+)
good point on the battery opinions. For the record, I am not sponsored by ProMatch (or anyone else) - I have just been very happy with their performance and customer service.
Kinda like the X-Ray, I am not sponsored by them, but I would (and have) recommend the X-Ray to anyone.
rctoyguy is offline
Old 04-13-2005, 02:04 PM
  #1728
STOCK ,19T,AND SOON MODDIFIED AS SOON AS I CAN DEAL WITH A FASTER SPEED
313XRAY is offline
Old 04-13-2005, 02:09 PM
  #1729
In that case look for Dumas' setup on rcamerica.com are you gonna run carpet only? I would also recomend gettting a multidiff in it and use the oneway for both stock and 19t
Old 04-13-2005, 02:12 PM
  #1730
ChrisP's Avatar
Yikes!!!!
I've seen no ned for a multi-diff on carpet....especially if you run at Larry's....very high bite.
I'm running a setup close to the Burch setup and it works very well in stock on a tight twisty track.
The car naturally steers and transitions very well.
you will probably want to look at a swaybar and some springs.
ChrisP is offline
Old 04-13-2005, 02:16 PM
  #1731
awesome, as windsor said look for those setups. Out west in Cali we are already racing outdoors so my setups have changed to rubber tires.
Old 04-13-2005, 02:21 PM
  #1732
what about chargers , when i go to the track all these guys have a shit load of electronics
313XRAY is offline
Old 04-13-2005, 02:31 PM
  #1733
whats ur budget? 200? LRP Pulsar 2 or the Orion Vantage for the latest technology. check the latest ver of car action they did a review of 10 chargers or something of that nature.
Old 04-13-2005, 02:33 PM
  #1734
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
can someone post a asphalt setup for a med bite track, we use cs27's.
L.Fairtrace is offline
Old 04-13-2005, 02:34 PM
  #1735
Fairtrace, what class?
Old 04-13-2005, 02:52 PM
  #1736
I JUST DONT KNOW WHAT ALL THAT STUFF IS . and im to chicken to ask
313XRAY is offline
Old 04-13-2005, 02:56 PM
  #1737
ChrisP's Avatar
Never be afraid to ask.
I would highly suggest checking out Larry's Let them know your situation and one of the guys there will be more than happy to help you outand walk you through what you'll need.
ChrisP is offline
  #1738
stock, 19 turn. I have never run outside on asphalt or with rubber tires so it should be fun I just need a starting setup and I can work from there.
Old 04-13-2005, 02:59 PM
  #1739
fairtrace- your gonna run diffs? or spool
Old 04-13-2005, 03:02 PM
  #1740
scoobydo's Avatar
I'm down with that too.
I need a starting asphalt setup for 19turn using a spool. Everything I run across for the FK05 is for carpet or rubber tires on carpet.
scoobydo is offline
