Like Tree1Likes
Xray T1FK05
Old 05-29-2005, 01:32 PM
  #2476
Twin-Kyle's Avatar
Originally Posted by skinart76
The shock ends are a PITA to thread on to the shaft. It is possible without it (as I have done several times), but it is hard not to score the shaft up without it. (Look for "Locking shock shaft pliers" from [url
www.teamtamale.com[/url])
When I did mine,I pretapped the shock end like the instructions said then I put some 10w30 oil in the shock end.Ran the screw in and out several more times then put the shock shaft on.
No problem.
Twin-Kyle is offline
Old 05-29-2005, 05:29 PM
  #2477
scoobydo's Avatar
You guys see that New FT TC4?
People are drooling all over it because it finally LOOKS competitive.
They basically made the chassis look like an XRay! j/k
Shafties, save your drool, get a Pro4 2005 Spec or switch to Xray.
scoobydo is offline
Old 05-29-2005, 06:00 PM
  #2478
NVisible's Avatar
Originally Posted by HRCRACER123
P.S- Is anyone else having problems with stripping out the bottom chassis screws? I have to buy new bulkheads now because the screws are stuck in them after having to drill them out.
What i did was drill the head off of the screw (is this what you did?) and remove the bulkhead from the chassis. There will be a bit of the screw hanging from the bottom of the bulkhead. Slap that little bugger in a vice and spin the bulkhead, thus removing the screw.
I put a little bearing lube on the shoulder of the screw (the part that goes like this \_/ ) and they come out with no problem now.
NVisible is offline
Old 05-29-2005, 06:18 PM
  #2479
scoobydo's Avatar
That is why people are putting CA on the countersunk holes, so they don't strip out. Its less messier than lube
scoobydo is offline
Old 05-29-2005, 07:06 PM
  #2480
NVisible's Avatar
i beg to differ. I have zero mess from putting some lube on my screws, you dont need to slobber all over them. Id rather not put CA on my holes either, as it can dry a little rough, or thicker one hole to the next, thus creating more problems. Plus, i can wipe away any excess lube i may have. Id need a debonder for any CA that may get away on me
NVisible is offline
Old 05-29-2005, 08:31 PM
  #2481
duckman996's Avatar
Trader Rating: 14 (100%+)
John D,
You always have the coolest red accents on your car ... only one complaint, the cracked top bumper
Martin
duckman996 is offline
Old 05-29-2005, 11:40 PM
  #2482
John Doucakis's Avatar
Originally Posted by duckman996
John D,
Martin
Yep, I noticed after I took the pics ! oh well..
John Doucakis is offline
Old 05-30-2005, 12:25 AM
  #2483
rccarusa.com's Avatar
Default IF ONLY MY EYES HAVE X-RAY...VISION
http://www.rccarusa.com/DSC01149.JPG
does...anyone know this player
Natedog
rccarusa.com is offline
Old 05-30-2005, 04:32 AM
  #2484
Suggestion...
Put some CA in a beer cap, use a Q-tip to absorb some, wipe in the counter sink. No mess, No CA getting away from you, and very consistent from hole to hole. Can do all of them in a minute if its dissassembled at the time.
MartynD is offline
Old 05-30-2005, 10:50 AM
  #2485
NVisible's Avatar
thats a good plan. a beer cap eh! are you suggesting i have many beer caps just lying around?!
yes, yes i do :\
NVisible is offline
Old 05-30-2005, 11:34 AM
  #2486
Just received my bearing for my diff should I just go and replace them or wait for the others to go first .
sportracer is offline
Old 05-30-2005, 11:46 AM
  #2487
Jimmy Morris's Avatar
I just drilled through the screw with a bit just smaller then the shaft, then with a screw extractor thinger I was able to back them out by lightly tapping it into the hole i made and turning it with some pliars. The extractor i got from a tap and die set my dad has. It loks sorta like a drill bit but with backwards threads. I'll post pics if anyone wants to see what I am talking about.
Jimmy Morris is offline
Old 05-30-2005, 12:01 PM
  #2488
HarshGuy's Avatar
I would just replace them, if your luck goes anything like mine, they'll go critical mass and implode right in the middle of the main where you're having the best run of your life :|
HarshGuy is offline
Old 05-30-2005, 12:05 PM
  #2489
JBennett's Avatar
Post
I have a problem with my car from my last race. I was winning the race then my car just swiched ends and cost me the race. I been having this problem all race day. What can I do to fix this?
JBennett is offline
Old 05-30-2005, 01:12 PM
  #2490
Congrats to Jarrod Scott and Alex Lopez. Way to represent guys!!
Art Jensen is offline
