Ask Steve "The Evicerator" Weiss
#6001
Seized bearing in Velocity 6.5...
Hey guys,
I seized the main (front) bearing in my 6.5 Velocity motor with the ribbed endbell and sintered rotor. I want to just replace the bearing, but can only find a bearing kit with a new endbell for $30. Does anyone sell just the bearings?
#6002
Hay Steve, I have a gtx that has no breaks and no forward until about 1/2 throtle. The power goes through the esc from the beginning of the trigger but the car does not move until about 1/2 throtle. All the settings are in a nutural position on the radio and the esc has been reprogramed to the factory settings. What should I do?
#6003
The Evicerator
Sounds like something's the matter with your GTX... send it in to me w/ a service form and I can probably get you taken care of.
#6004
The Evicerator
Sorry, We only sell the bearing already pre-installed into an endbell because of the problems we have seen with people trying to A. Remove the bearing from the endbell and B.) re-install a new bearing into the endbell.
#6006
Scuba just wanted to say thanks for all the help at the nats....later Drew
#6008
The Evicerator
#6009
how you feelin scuba? good enough for a litttle night race tomorrow? hopefully i see you there buddy later E-MAN
#6012
hey steve i have a gtb and i'm running a brush motor on it. today i was practicing and it was working all good until i came out or a turn and then i gave it gas it wouldn't go it just surged when i give it gas. i tryed another motor and it did the samthing, then i changed remotes and still the samthing.
also on the speed control i'm not running all three wires to the negative on the motor, i have one wire that is soidered to all the tabs whitch then goes to the negative on the motor. could this cause a problem?
i'm not sure what i need to do about getting it fixed.
i need a speed control for the jbrl this weekend, so please let me know what i need to do.
thanks
thanks
#6013
The Evicerator
The Super Electrics are those big, 1/8 electric cars, right?
I'm not even really sure where to begin with recommendations for that car... the only things that I can think of for sure are:
Upgrade to a sintered rotor
Probably gear low ... around a 9.0:1 to start and monitor ESC and motor temps... if after a 5 minute run they are lower than 170 you can gear up a tooth a time.
Sorry I don't have better recommendations... those 1/8 electric cars are generally something I'd try a different system in instead of the SS 5800.
#6014
The Evicerator
#6015
The Evicerator
metal,
I'm not certain but it sounds like your ESC might have a few damaged mosfets.
The way you have it wired shouldn't have caused any problems.
When running a brushed motor were you running a schottky diode on the motor...? Extensive running without a schottky could have lead to the damage you might have.
I would definately recommend bringing the ESC in... if you want the fastest service unfortunately you'd probably have to walk in with it... if you mail it in the turn around time is generally 3-5 days...which isn't slow by any means... but won't help you get on the track this weekend!
Let me know if you need any more help!
thanks
thanks
