Ask Steve "The Evicerator" Weiss >
Old 06-21-2007, 03:01 AM
  #4846
Drewdc90's Avatar
Hi Steve a question about whether a motor is ok or not. I recently had my Spread Sektrum GTB stop after a couple of races running a 5.5 with sintered rotor. You guys very kindly replaced it and suggested the fets may have been shorted out and to check the wiring. This was the first thing I did when it stopped and could not find a problem. Now I have the replacement is there any way I can check the motor (besides connecting it to my GTB) to make sure was it was not the cause of the speedy failing?? I am a little apprehensive about putting everything back as it was and suffering the same fate. I know I can run my 4.5 and 3.5 but I want to run the 5.5 and know its ok. Any suggestions on how to check it out besides running it on someone elses GTB?? Thanks Drew.
Drewdc90 is offline
Old 06-21-2007, 03:46 AM
  #4847
dash yonkuro's Avatar
Originally Posted by Steve Weiss
Hey Dash,
The ESC and motor should mount up just fine in your mini... I'm not sure that you will be able to get suitable gearing for the 4.5 motor though... generally speaking the 4.5R is a very high RPM motor and to gear it properly you need to put a pretty small pinion gear in your car.
That being said it still might be a bit much power for the drivetrain in your car to handle... but I've never tried it so I can't really say for sure.
I would say try putting the smallest pinion gear on that you can find and carefully monitor the temperature of the ESC and motor while running.
We like to see temps under 175 degrees.
i see... thanx boz!
dash yonkuro is offline
Old 06-21-2007, 07:59 AM
  #4848
The Evicerator
Hey Drew,
Unfortunately there's really no way for you to run or check your motor there by yourself.
I take it you didn't send your motor in with your spread spectrum GTB when you had it replaced or else we would have given that the once over while we had it.
We generally like to see both the motor and the ESC in the event of a failure just to prevent a situation like this.
There are some rudimentary things you can do such as check to see that the rotor spins smoothly and doesn't get caught at any point or smell it or even take the front side endbell off to inspect for shorted coils, but there is nothing you can really do on your own to check the status of the sensors in the motor.
More than likely the motor is ok... I very rarely see motor failures and when I do they are very obvious motor failures, IE bearing failures.
I hope this helps out!
Steve Weiss is offline
Old 06-21-2007, 02:28 PM
  #4849
Drewdc90's Avatar
Thanks Steve I didnt think to send the motor as the rotor turns ok and the front bearing is also ok. I will try my 4.5 to make sure all is ok then give the 5.5 a short couple of runs before I race it. Thanks Drew
Drewdc90 is offline
Old 06-21-2007, 07:00 PM
  #4850
chris72983's Avatar
I was wanting to get a sintered rotor for my older 13.5 that has a bonded rotor. Does anyone know the part number for the rotor to upgrade mine?
chris72983 is offline
Old 06-21-2007, 08:39 PM
  #4851
The Evicerator
Old 06-22-2007, 07:38 AM
  #4852
chris72983's Avatar
# 5908
Old 06-24-2007, 10:34 PM
  #4853
stonedgti's Avatar
Trader Rating: 15 (100%+)
Hey Steve,
I have the regular GTB, but just got the spektrum system. Can I sent it in for an upgrade? How much would it cost?
stonedgti is offline
Old 06-24-2007, 11:21 PM
  #4854
The Evicerator
Stonedgti,
I don't have all the pricing information available to me right now... you might want to try to call or contact customer service tomorrow with your question!
949 833 8873
[email protected]
Originally Posted by stonedgti
Hey Steve,
Old 06-24-2007, 11:37 PM
  #4855
Trader Rating: 40 (100%+)
Great win saturday steve. Your car looked dialed. We missed you at Corona today we had another 10 cars in mod today.
King of B Main is offline
Old 06-24-2007, 11:44 PM
  #4856
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
May I lend a hand?
I was just checking it out the other day...it's the "option 1" price:
"[G] GTB DIFFERENT MODEL EXCHANGE PROGRAM: Customers returning a GTB ESC (#1710, #1710-L, #1711, #1714, & 1715) for non-warranty service can request to replace their unit with a different Factory-Remanufactured GTB model for a $69 exchange price. Indicate model and Service Code (G) on Non-Warranty Service Form."
Turbo Joe is offline
Old 06-25-2007, 08:04 AM
  #4857
The Evicerator
Thanks Mike!
Yeah, wasn't really feeling up for a hot day out at corona... maybe some other time!
Joe,
Thanks for putting that up there! I knew we had the information somewhere it was just late last night and didn't have the energy to look it up!
Old 06-25-2007, 08:23 AM
  #4858
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Ole Weiss one,
If the blue sky in Big Bear were to receive winds from smoggy Los Angeles at 3 miles an hour while carrying say 2000 PPM. How long would it take to turn Beautiful Big Bear weather into another Los Angeles? Just a thought.
F. Mendoza is offline
Old 06-25-2007, 08:32 AM
  #4859
The Evicerator
I think if the air quality was poluted to 2000 ppm in the LA area we wouldn't be having this discussion...we would have all asphixiated long ago
Old 06-25-2007, 08:38 AM
  #4860
Steve on the 13.5 motor is there anyway to shorten the wires coming out of the motor going to the ESC?I hate having to coil all that wire.
BullFrog is offline
