Ask Steve "The Evicerator" Weiss
#4861
The Evicerator
Well, we really don't recommend trying to shorten those wires on your own...
But I have seen people cut sections out of the middle and solder/shrink wrap them to get them to the length they want.
#4864
The Evicerator
Most people have been running their sintered 13.5's around 4.5-5.0
#4865
straw hat?
#4866
The Evicerator
Damn straight!
I'm still waiting for that thing!
How are things baby blue?
#4868
The Evicerator
10.5 Pro gearing: 5.5FDR for most applications...sometimes a bit taller...sometimes lower.
#4872
Steve I own a Novak GTX and was at the track the other day and I came to a complete stop to check some thing and when I was done I pulled the throttle and it wouldnt move and eve the stering didnt work. So I pulled it off the track and every thing was fine no wires undone or bars unsoledered then I flip the swich off then on and a small pop and a little smoke came from the negative end of the curicut board and it worked fine I took it out that night and put all new wire on it and nothing was touching that shouldnt have. Nothing else happend and it still words fine but I herd that one of the fets could have blown out. I was wondering what could have happened.
#4873
The Evicerator
Yeah, something definately could have let go, if not a transistor than an internal schottky diode.
Are you running an external schottky on the motor and is your power cap in good condition?
#4874
Hello, my gtb has started having issues. When I hit the accelerator (trigger) it stutters quite a lot. Sometimes it doesn't go full speed either. I referenced the troubleshooting section of the manual, which the suggestion is wiring, or the capacitor. The wiring is good, however how do I tell if a cap is bad. It looks fine, no burnt smell, is intact. And it has only had a 13.5 on it for the last couple of months.
#4875
STEVE,
QQ is Novak likely to be packaging the GTB 1711 and 13.5SS motor any time in the future. Considering a purchase in the near future but dont want to jump if something is in the works.
