Like Tree4Likes
Tamiya TRF417
Old 10-24-2012, 03:24 AM
  #4111
Originally Posted by ngo8
tamiya ones are not available yet and wont be out till after the new 417 comes out .
New 417? WhT is that. When will be out? Any write up or review link?
grauco is offline
Old 10-24-2012, 04:52 AM
  #4112
2-Bad's Avatar
Trader Rating: 24 (100%+)
TRF417 V5
2-Bad is offline
Old 10-24-2012, 01:08 PM
  #4113
New Smokem Chassis released, seems interesting for carpet season.
redrc.net/2012/10/smokem-racing-417mx-chassis
-no86- is offline
Old 10-24-2012, 01:11 PM
  #4114
CraigM's Avatar
Trader Rating: 34 (100%+)
We've been testing it on asphalt lately, results are promising
CraigM is offline
Old 10-24-2012, 01:44 PM
  #4115
DaveG28's Avatar
Trader Rating: 65 (100%+)
Two must have things for 417 gear diff and spool they just work to good and solve alot of problems .
http://www.roche.hk/shopping/index.p...product_id=488
http://www.roche.hk/shopping/index.p...product_id=489
Do they require blades?
DaveG28 is offline
Old 10-24-2012, 01:54 PM
  #4116
sounds good have you ever tried it on carpet? in my opinion it could be a great alternative instead of the normal 417/x chassis
-no86- is offline
Old 10-25-2012, 07:20 AM
  #4117
Marek Gadomski's Avatar
hey
can u give me some advises hot to make car better and more stable on really low grip carpet ? i have front 500 k diff some changes in suspension anti-dive anti-squad etc ?
thanks for all replies
Marek Gadomski is offline
Old 10-25-2012, 07:47 AM
  #4118
Here is a set-up for foams. I know I must be the only one on here who races it on foams and carpet. But here we are.. Basically its the quickest car at the club.
http://thercracer.blogspot.co.uk/201...07351542218423
Other info, non cut motor mount (we all run the solid mounts).
Qatmix is offline
Old 10-25-2012, 07:51 AM
  #4119
but we must run on rubber
Old 10-25-2012, 10:59 AM
  #4120
ngo8's Avatar
These are direct replacement parts so if you're running spool up front no blades gear up front yes blades and gear diff in the rear yes you need blades these diff cups are allot harder and will last allot longer the the original aluminum ones .
ngo8 is offline
Old 10-25-2012, 11:05 AM
  #4121
ngo8's Avatar
Marek when we start our carpet season and the carpet is loose and the traction is minimum or when we change the layout i always start by making the camber links longer by putting the ball stud on the most inner position that makes the car feel really planted and stable and also try a softer tire not really sure what tires you run but traditionally i run 32s and maybe ill use 28s for a couple of heats till the traction comes up just try one at a time and good luck.
ngo8 is offline
Old 10-25-2012, 12:47 PM
  #4122
hey
try to use softer shock oil and raise the camberlinks on the inside. maybe to 5mm/4mm in front and rear. it should increase smooth running.
-no86- is offline
Old 10-25-2012, 01:52 PM
  #4123
CraigM's Avatar
There are no carpet tracks in Australia really, but based on asphalt running I think it would be better than the kit chassis on the rug. It makes the car a lot smoother to drive
CraigM is offline
Old 10-25-2012, 03:45 PM
  #4124
JoeyE's Avatar
Trader Rating: 45 (100%+)
What do ou recomend on getting more rear traction on a lose permanant track? Shock position, droop, camber, etc...
JoeyE is offline
Old 10-25-2012, 10:44 PM
  #4125
CraigM's Avatar
On or off power?
CraigM is offline
