Like Tree4Likes
Tamiya TRF417
Old 06-28-2012, 01:01 AM
  #3361
Originally Posted by Nuno Gancho
do anyone have the table for reference regarding the HINGE BLOCKS, SPLIT FOR TRF 417, and they may be assembled in both side how do I know which side is correct.
thank you.
The marks on the split block should face inside for the right combo, fx u have a xa-a split block and want xa block in the rear front position, then u place xa facing inbound that gives u a xa block in the rear front position.
Here is a chart over the block.
Hope this helps
http://www.petitrc.com/reglages/tami...art/index.html
Cp Grafix is offline
Old 06-28-2012, 05:35 AM
  #3362
dawgmeat's Avatar
Which xrings do i use for the shock, 50 or 70 Durometers?
dawgmeat is online now
Old 06-28-2012, 08:43 AM
  #3363
Trader Rating: 47 (100%+)
50
transplantlife is offline
Old 06-28-2012, 08:44 AM
  #3364
dawgmeat's Avatar
Originally Posted by transplantlife
50
Old 06-28-2012, 09:26 AM
  #3365
Leester's Avatar
Trader Rating: 23 (96%+)
"Looking at this picture here, does anybody know where I can get this Tamiya logo in vector? or know what font this is?"
PM him here @ FWM.
Leester is offline
Old 06-28-2012, 01:22 PM
  #3366
Trader Rating: 153 (100%+)
for the 417X
do you guys run the original alu/blue 44 shaft or the steel 44 or 46?
plan to run spool
S I O is offline
Old 06-28-2012, 01:35 PM
  #3367
Originally Posted by S I O
for the 417X
plan to run spool
run the 46mm steel in front for smoother steering run the 44mm in the rear
Old 06-28-2012, 02:09 PM
  #3368
CraigM's Avatar
Trader Rating: 34 (100%+)
DCJs front and rear
CraigM is offline
Old 06-28-2012, 02:10 PM
  #3369
artwork's Avatar
Trader Rating: 88 (100%+)
Originally Posted by CraigM
DCJs front and rear
What would be the reason to run DCJ's in the rear...?
artwork is offline
Old 06-28-2012, 02:43 PM
  #3370
i use 44mm back and front , i had a problem with the front steering upright breaking when i had the 46mm shafts in. It only stopped happening when i changed to the 44's.
With the standard plastic outdrives the 46mm was fine.The problem started when i fitted steel spool outdrives.
Also has anyone got any feedback on the mr33 red springs, ive had good results from using blue f blue R, but im going to try the reds tommorow.
vwvrt is offline
Old 06-28-2012, 05:23 PM
  #3371
I don't know how it works, but there have been reports that you get more rear traction with dcj's. Tamiya magic at work here?
edit: did a little more reading on this, and what people have been saying is that the rear became more planted and the car turned better. Felt more like "on the rail" feeling. Times improved .2-.3 sec, etc.
anyone noticed that?
inpuressa is offline
Old 06-28-2012, 05:37 PM
  #3372
Trader Rating: 19 (100%+)
when i use to my 417 about a year ago, I never used anything but cvd's. I had steel 46's in the front and kept right up with cars that had ecs's in them. Keep them clean and they stay nice and smooth for the life of the car, thats tamiya magic at work might have something to do with the way the suspension is designed on that car as well.
COLD AS ICE is offline
Old 06-28-2012, 11:44 PM
  #3373
CraigM's Avatar
I wish!
They give more on power grip and a bit more rotation. They don't wear as much either
CraigM is offline
Old 06-28-2012, 11:50 PM
  #3374
CraigM's Avatar
The car is much smoother to drive with DCJs in the front at least. It might not be much faster but it's definitely better
CraigM is offline
Old 06-29-2012, 12:38 AM
  #3375
craig how do you like the dcj in the rear
