Tamiya TRF417
#4096
Hy there!
I have a question regarding the 1mm hole in the shock cap.
I usualy use it on asphalt. Is it also recomended on carpet?
Thin i read that the team drivers dont use it on carpet.
I ask because my lak of training track time. I usualy came to the race track sunday morning, and so there is no time to play with such things.
Greetings Rainer
Greetings Rainer
It's all in your driving style. I use 1mm holes on high-traction carpet and I love it. Try it.. And get yourself a spare set of shock caps... Or shoe goo to clog them if you are really cheap.
#4097
Hey Folks,
does anyone use Anti-Dive or Anti-Squad? How will the car react on these changes? I want to try a few new things on my next run.
#4098
Anti-dive yes, anti-squat not so much. Neither are huge changes, the anti-dive improves the car under brakes and gives better turn in. Anti-squat does just that, it stops the car squatting on power and improves on-power steering. I find it makes the car snap oversteer off power though.
#4099
Thanks for the quick answer
#4101
TA05 Gear driff use in 417
Hi,
Have any one tried to use a TA05 Gear driff on a 417? i kind of fed up that the 417 gear driff 2 cop joint is easily destroy whenever the shaft protector lost.
So i was told the TA05 uses a hard steel with out the need of shaft protector so is it good? have any one tried?
#4102
Hi,
Other people on here take the damaged outdrives and grind them out to fit TC6 blades from Associated.
problem solved.
#4103
Hi,
I was having the same problem too in my 417x until i tried this TA05 outdrive it got much better, now i don't even have to buy the blades anymore since the 44mm shaft fits right in without it. Make sure that you use the 10mm spacers so that the bearing housing sits well on the chasis.
#4104
Two must have things for 417 gear diff and spool they just work to good and solve alot of problems .
http://www.roche.hk/shopping/index.p...product_id=488
http://www.roche.hk/shopping/index.p...product_id=489
#4105
Arena also make hardened steel outdrives, about 1/2 the price of the roche ones
Not using a blade will make the rear suspension bind up under power, I would not recommend that.
New tamiya blades are on the horizon, 3.5mm and made of delrin. Of course, we'll have to change or file all of our existing outdrives
#4106
What about Tamiya's new steel outdrive 54425?
#4107
This is an easy fix, use different blades. I use SpecR that are a lot stronger and I haven't had a single blade failure since. I'm on my second pair of outdrives since I got my car, the first set only lasted 5 battery packs with the original tamiya blades.
problem solved.
problem solved.
All you solution is great.... i tired the TA05 not a good solution.... i ll go with dave g. soution. i think its the best.
Thanks guys.
#4108
#4109
#4110
