Litemodz CVD
Old 09-29-2010, 11:53 AM
  #301
Fred Hubbard's Avatar
Originally Posted by jag88
What's happening with these guys ? Web site has been down a couple of days.
Site is up, was up last night also.
Fred Hubbard is offline
Old 09-29-2010, 12:54 PM
  #302
GSM Storm's Avatar
Trader Rating: 114 (100%+)
Default Email
Jon
I sent you a email regarding the CVS drive shafts, did you receive it?.
Regards
Gary Sturdy
GSM Storm is offline
Old 09-29-2010, 01:12 PM
  #303
Gary, you have a couple of PM's.
jonrg is offline
Old 09-29-2010, 02:44 PM
  #304
jag88's Avatar
..got it to work ... Thanks.
jag88 is offline
Old 10-01-2010, 07:30 AM
  #305
jag88's Avatar
jonrg, you have PM.
jag88 is offline
Old 10-02-2010, 07:05 PM
  #306
jag88's Avatar
.... hello jonrg, anybody home ??
jag88 is offline
Old 10-03-2010, 10:06 AM
  #307
Hi, is any one using these xray t2/t3, My fronts seem to be very tight in the steering knuckle and its wore the black anodising off- thing is if its rubbing then its binding as well. I ve taken it all apart and checked for screws coming through etc and there nothing there.
michael.branth is offline
Old 10-03-2010, 10:26 AM
  #308
Mine were like this with the mi4lp... Slightly large and the screw coming through and hitting it... Not the best really.
Cocoon is offline
Old 10-03-2010, 01:16 PM
  #309
Mine Are'nt hitting any screws, its in the wrong place, I am fine with them not looking the best but it must be rubbing which can'nt be good!!!
Old 10-04-2010, 04:46 AM
  #310
With the Xray hubs, a bearing spacer between the two bearings as Tamiya, Hot bodies, associated and others use will help keep the axle square. There is enough clearance on the flange to hub unless the bearings have too much play or the hub itself has play where the bearings sit.
The hub spacer as used by many other models, help keep the bearings and axle square to each other and also reduces stress placed on the hub under load.
If there is marking on the outside of the CVS , the bearings and or hub need to be looked at. The defection of the bearing/hub needs to be eradicated as both camber and caster will be continually moving under cornering producing erratic handling.
jonrg is offline
Old 10-05-2010, 03:10 PM
  #311
Impulse_racer's Avatar
Default PM
Jonrg you have a pm.
Impulse_racer is offline
Old 10-06-2010, 07:19 AM
  #312
jag88's Avatar
jonrg, PM
jag88 is offline
Old 10-10-2010, 12:19 PM
  #313
I and and alot of the racers at our local track are VERY disappointed in this product. We've had nothing but problems with them. They are constantly breaking.both versions are breaking.
Confidence in running these are not there. The warranty is good only if the replacements work .
Is a refund a option?? They were very expensive. Either version does not work.
Like I said before we the racers are VERY disappointed
Al Sodano is offline
Old 10-10-2010, 12:29 PM
  #314
Al, you have PM
jonrg is offline
Old 10-10-2010, 01:09 PM
  #315
san.'s Avatar
Trader Rating: 61 (100%+)
I was at Horsham this weekend and witness two different drivers having problems with their Litemodz CVS's.
Al Sodano and I were in the same heats and he couldn't finish the first two quals because these CVS's were blowing up and locking. I was surprised he kept trying these with no luck. I asked him to show them to me and they were locked...lol Couldn't budge them at all. Finally he gave in and tried a different manufacturer and was able to finish the last two races.
Al seems to be loyal to Litemodz, hope they do the right thing for him.
san. is offline
