Team Associated TC6 Thread >
Like Tree20Likes
Old 04-16-2013, 12:03 PM
  #9106
turtlehill's Avatar
Hi Luke,
I had the same problem with breaking blades and outdrives. I put a gear diff in the front since it has metal outdrives and I haven't had any problems since then. Be sure to use a very stiff diff oil. I'm using Gravity 1m CST in two cars and I'm currently testing the Gravity 2.5m CST in my third car. The bottom line is I'm not breaking blades and outdrives anymore.
turtlehill is offline
Old 04-16-2013, 04:21 PM
  #9107
Thanks YoDog I appreciate your input.
JBorchid is offline
Old 04-17-2013, 12:29 PM
  #9108
Trader Rating: 33 (100%+)
Default tc6 gearing
Does any body have a good starting gear setup for a 10.5? No boost, 12° can timing. Maybe a recommended fdr. Im planning on running 64p.
fifty-one is offline
Old 04-19-2013, 01:40 PM
  #9109
TT_Vert's Avatar
Trader Rating: 72 (100%+)
Can I ask a favor of someone who has a tc6 gear diff handy to measure? I need the exact width of the case from end to end where the bearing rides on the diff housing itself (Not end to end of the outdrives). Want to see if it is wide enough to fit into my TC5.
Dave
TT_Vert is offline
Old 04-19-2013, 10:32 PM
  #9110
J_Bone's Avatar
To strap down the battery, what's the best alternative to battery tape?
J_Bone is offline
Old 04-19-2013, 10:40 PM
  #9111
DesertRat's Avatar
Put a few pieces of double sided tape with the backing still applied on the bottom of the battery for padding (1/4 and 3/4 the way along the pack seems to work best) and two pieces of strapping tape looped through the hold-downs should hold the battery just fine, don't strap it in too hard or you can have some dreaded chassis tweak.
DesertRat is offline
Old 04-20-2013, 12:52 AM
  #9112
rbarciko's Avatar
Dave
I use the gear front and rear in my TC6, and it is 23mm for the inside dimensions:
rbarciko is offline
Old 04-20-2013, 12:57 AM
  #9113
rbarciko's Avatar
i use the Reflex RSD battery hold down system. it is pricy at $30, but I have never had a battery pop out under hard impact:
http://www.reflexracing.net/RSD-AE-T...em_p_1300.html
rbarciko is offline
Old 04-20-2013, 09:57 AM
  #9114
I put 3mm shims under one side of the battery tape tab to provide some clearance for a 3 Racing (or similar) Velcro strap. Strap is about 3 bucks. The battery is secure and the shims make the strap easy to slide back and forth.
Make sure you put the double sided tape down as suggested above to float the battery. I really feel that it helps
capnkids is offline
Old 04-21-2013, 04:38 PM
  #9115
Regional Moderator
nitrous36's Avatar
Not trying to derail thread, but just want to put this out there. Anyone in or around wilmington, NC that would be interested in organizing PL races?
Going to make a seperate thread for this, but figured why not ask here as well.
nitrous36 is offline
Old 04-22-2013, 06:40 AM
  #9116
Trader Rating: 33 (97%+)
Quick update from a few pages back about my concerns with the motor potentially sliding forward on the mount.
I dropped in a 3.5T motor in my car at the track yesterday and was getting some fairly impressive speed, however, my skills weren't quite where they need to be to handle that much power just yet and I clipped a corner while accelerating full throttle into the back straight sending my car into a "Top Gun Tailspin"... maybe a dozen or so rotations before I realized my car lost throttle response, I just couldn't pull out of it and had no ejection seat! As luck will have it, the mesh was still perfect! Turned out that my sensor board(s) failed... still haven't isolated the problem to the motor or ESC just yet but I suspect a chain reaction occurred where the motor went out first, then my repeated attempts to tinker with the motor caused the ESC to fail next.
Also note that when I pulled my old 5.5T motor out, the Amazing Goop glue popped right out without any special effort, it remained all in one piece and peeled right off without any mess
billdelong is offline
Old 04-22-2013, 02:28 PM
  #9117
TT_Vert's Avatar
Thanks but I'm looking for the end to end length where the bearing rides on the gear diff itself.. Does the gear diff ride in the entire width as the ID of the diff bearing?
Dave
TT_Vert is offline
Old 04-22-2013, 03:21 PM
  #9118
YoDog's Avatar
Trader Rating: 28 (100%+)
Dave
Here is a drawing generated from a Solidworks model I made for the TC6.1 spool which fits the same as the diff.
YoDog is offline
Old 04-22-2013, 03:58 PM
  #9119
Rick Hohwart's Avatar
Default New setup posted
Mike Haynes - Mile High Indoor Champs TC Modified
Mike finished 2nd in TC Modified using a 6.5 motor. This is a great easy to drive setup.
Rick Hohwart is offline
Old 04-23-2013, 08:18 PM
  #9120
J_Bone's Avatar
Thanks!! I used the servo tape under the battery and strapped it down with fiberglass tape.
Next question:
Has anyone had issues with the o-ring in the shocks being squished to tight? Mine do and I had to sand down the o-ring spacer. They were 3.92mm thick and I sand mine down to 3.6mm and it seems to be perfect. No more binding.
J_Bone is offline
