Team Associated TC6 Thread
#3091
i was having on-throttle understeer problem....then changed from 0 degree rear to 1 degree anti-squat...it is now better? should i futher make it to 2 degree anti-squat?
#3092
#3093
have found next faulty part... rear shock tower is not straight... one shock is set lower then second. Now when i set rear arm at 0 is not possible to set droops at 5. And very hard to tweak properly rear end of the car. Does somebody had the same problem with rear or front shock tower??? or just i have bad luck with that car...???
#3094
Ok so, i had to take off alu parts and the tower... and first tight alu parts and after that push the tower and tight it again.. And now is better! Still is little bit difference but is ok. Tweak is possible to set but still cant go with 5 droops on rear, so i had to set it 5.5 about
#3095
i got my dial-a-grip blocks today must say they look good, but don't think i quite follow the set up of them, could some one make a small vid for me? just setting
one block up and when i see it im shore i will then understand.
nigel
nigel
#3096
Had my first test drive with the Reflex springs on medium to high grip carpet today. It really makes a difference
The car rolls much less without losing grip, it just sits better on the road. I could drop my body one hole. Second positive thing I recognized was that the car now is much more calm when rolling over longitudinal ribs and when you integrate the curbs or the caps in your driving line. Nice!
I also used a one lb harder spring in the back to make the car turn better.
So after the Litemodz CVSevo and the Dial-a-grip another tuning part that really deserves its name! Thank you Christian!
By the way: Is someone using the RSD TC6 Vertical Ball Stud Shock Tower Mounts from Reflex Racing? Maybe someone independent who wants to share his experience (good or bad)?
#3097
Not sure where your question is but these are the basics. Put them on just like the AE blocks, only while tightening the main block screw into bulkhead you need to hold the block down to rest on the top set screw to locate. After tightening there should be tension on the top 1.5mm driver screw. Then lock the pin set screw againt hinge pins and drive like mad.
#3098
just a question is there any chance of getting some pins made that are the same length as tc6 arm pins and thickness that are threaded both ends so i can mount like this.cheers
#3099
hi verndog,
Attachment 775913
Attachment 775914
Attachment 775913
Attachment 775914
#3102
#3103
#3104
What oil do I run in the spec-r gear diffs?
#3105
