Team Associated TC6 Thread >
Like Tree20Likes
Old 01-27-2011, 02:59 PM
  #1591
Buckaroo's Avatar
Originally Posted by mugenize1
So we should be able to use this part from the TC5 and put the screw from the inside the only problem I see is that it will have to be threaded on the bulkhead also, would this cause a problem you guys think.
I wouldn't, no real way to ensure that everything is tight and indexed properly.
Buckaroo is offline
Old 01-27-2011, 03:28 PM
  #1592
F-1
Hello!
What parts should I have and what parts is most breakable?
Thanks!
F-1 is offline
Old 01-27-2011, 03:38 PM
  #1593
muststopcrashin's Avatar
i've got to say, so far i've only broke/lost a drive shaft pin, and i hit everything,but i have just been looking over my car and seem to have lots of play in my wheel bearings.has any 1 elts got this
muststopcrashin is offline
Old 01-27-2011, 03:47 PM
  #1594
Buckaroo's Avatar
The only thing that I've actually broken on my 6 is a left rear hub....bad enough that I also broke the outer race on the outer wheel bearing. All my fault, didn't get set for the dog leg on the track properly! All in all, I've found it to be more durable than my 5 ever was.
Buckaroo is offline
Old 01-27-2011, 05:26 PM
  #1595
slicendice's Avatar
Trader Rating: 23 (100%+)
Originally Posted by devilsquid
Anyone know of someone with a tc6 for sale?
LOL So u finally justifiied it (Tc6)
,Drew
slicendice is offline
Old 01-28-2011, 01:50 AM
  #1596
daleburr's Avatar
There is a bit of play between the bearings and the hubs even on brand new parts. The solution is to score the surface of the hub with a knife which will make the bearing a tight fit. See OJs guide http://cmldistribution.co.uk/news.php?view=0000001651
Some 5mm shim washers to get rid of any end-float on the driveshafts also helps; there are some included in the kit but I needed a bit more on the rear to get rid of the play.
If you do those two things there will be almost no slop at all and the car will feel a lot nicer.
daleburr is offline
Old 01-28-2011, 02:46 AM
  #1597
I'm yet to break something on my 6 and mine has flown into a fence a few times and a person!
Scooter79rs is offline
Old 01-28-2011, 06:19 AM
  #1598
Drew, no but I do have my momments of weakness and if the right deal came along well I guess I would own one.lol
devilsquid is offline
Old 01-28-2011, 08:28 AM
  #1599
Default Another quicky...
Could a couple of you please recommend a servo for this car? Planning on racing spec class (outside/rubber) till I can drive and then stepping up to the next level here in West Palm Beach. A Spektrum dx3s is in the mail.
I've been told something .10 or faster will make me happy, but that is all I know. Low profile, high speed, digital, high torque, titanium gears, uhhhh....yeah...I just know I need one to steer!
Building up the car now and this thread has already been very helpful.
Thanks for your help!
cvlooper is offline
Old 01-28-2011, 08:34 AM
  #1600
Trader Rating: 3 (80%+)
Most of the AE guys are running the xp digital DS1015
Price is reasonable and the servo is bullet proof.
Josh Hohnstein is offline
Old 01-28-2011, 09:00 AM
  #1601
It appears to be a best seller...
cvlooper is offline
Old 01-28-2011, 09:33 AM
  #1602
twk-b's Avatar
Originally Posted by F-1
Hello!
Thanks!
caster blocks and steering arms (usally stripping out because of the caster block breakage) are the only things that break really in SS TC, maybe the occasional rear hub if you like to throw it into the corners...in 17.5 or VTA the car is pretty indestructible...
-b
twk-b is offline
Old 01-28-2011, 10:06 AM
  #1603
Buckaroo's Avatar
I'm running a Savox 1251, and it's working perfectly, and priced right.
Buckaroo is offline
Old 01-28-2011, 01:37 PM
  #1604
corallyman's Avatar
Trader Rating: 101 (100%+)
Are Savox servos quiet, I have heard that they make some noise, if true, is it all the time or just when there is a load. I like quiet servos
Thanks,
Steve
corallyman is offline
Old 01-28-2011, 02:00 PM
  #1605
Mowell's Avatar
Thanks,
Steve
I also run a Savox mg1251 servo. It is awesome, but I haven't heard a louder servo. It only really barks with a load though.
Mowell is offline
