Team Associated TC6 Thread >
Like Tree20Likes
Old 06-14-2011, 05:47 PM
  #2926
azz187's Avatar
Default loose srews??
Had a great time with the car this weekend, had heaps of grip and the car felt awesome.
However after a few runs I'm finding the screws from the top and bottom deck backing up and loosening completely, so I'm having to re-tighten the chassis frequently.
Is this a problem that anyone else has had? Looks like I might have to get out the locktite...
Cheers.. Azza
azz187 is offline
Old 06-14-2011, 05:56 PM
  #2927
Maybell's Avatar
Cheers.. Azza
I think you are experiencing a little "break-in" "stretching" of the threads while the car is new. I have noticed this with other cars. The screws should stay tight shortly.
Maybell is offline
Old 06-14-2011, 05:59 PM
  #2928
AM03GT's Avatar
Here's Pics...
AM03GT is offline
Old 06-14-2011, 08:19 PM
  #2929
Originally Posted by Verndog
There really is no need, I thread lock them to "factory" block setting with a gage for anyone preferring to leave them there only. It's best to use a feeler gage between block and chassis to set when you adjust them (to get perfect), then use the top set screw to add just a touch of tension after locking down main screw to prevent it from being able to back out.
Cheers Verndog!!
Lionel S is offline
Old 06-15-2011, 08:25 PM
  #2930
Trader Rating: 19 (100%+)
Default Finally got my TC6's put together and my TC5 Exotek setup
Just finished the setup on all 3 TC's .. the only thing i am short now is gearing for the 13.5.
Car 1 and 2 are identical TC6's except motors:
Car: Team Associated TC6
Speedo: Tekin RS Pro
Motor: 1 has Tekin 13.5 and 1 has Tekin 17.5
Receiver: Spektrum 3520
Servo: JR DS9100S
Transponder: AMB RC4
Body: Mazda 6
Car 3 is a TC5
Car: Team Associated TC5 w/ Exotek Conversion
Speedo: Speed Passion Cirtix Stock Club
Motor: Novak Ballistic 21.5 (have Novak 25.5 also)
Servo: KO Pro PDS-2163 ICS
Transponder: I need to get one for this car =(
Body: Mazda 6 for now but need a VTA body
I cannot wait to get them out on the track to play. The wife is giving me a hard time for throwing so much money at them but not even putting an hour on the road with them yet lol.
specc is offline
Old 06-16-2011, 04:34 AM
  #2931
Originally Posted by specc
J
Nice bodies, nice cars.
Please try do something with wiring.
Engines like on pictrures doesn't need 14awg wires, 16awg will be ok.
Try made wires clean,short,nice.
Wish you good luck!
m
M.Abramowicz is offline
Old 06-16-2011, 06:53 AM
  #2932
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Servo: JR DS9100S
Body: Mazda 6
Car 3 is a TC5
nice pcars but FYI on the tekin you shouldnt heatwrap the wires in the esc the tekin uses those post to release heat like a heatsink by covering them up you will be retaining more heat just fyi
Marcos.J is offline
Old 06-16-2011, 07:04 AM
  #2933
Thanks for the feedback, i will be removing the shrink wrap tonight.
specc is offline
Old 06-16-2011, 07:42 AM
  #2934
Servo: JR DS9100S
Body: Mazda 6
Car 3 is a TC5
Treaded tires are on backwards on the TC6.
For a Tekin 13.5 on boost in my TC5/TC6 I typically use 24/87 48 pitch with 40 boost (5400-20,000 RPM), 14 turbo, 0.5 delay and level 2 turbo. This is with standard size slicks like Sweep EXP on a medium sized outdoor track. Treaded tires are typically a bit taller than slicks so if you're running the treaded tires and boost/turbo drop the pinion a tooth or 2 and check your temps frequently.
spongerX is offline
Old 06-16-2011, 07:53 AM
  #2935
The tires were more for just the photos.. they will not be used. Thanks for the feedback on the 13.5 !
specc is offline
Old 06-16-2011, 11:25 AM
  #2936
Oh and I run as low motor timing as possible. The older Tekin 13.5 motors came factory default around 8 or 12 degrees of motor timing. The newer ones are around 4. I adjust the ring to get as close to 0 on the can marking as possible to get more torque at lower RPMs.
spongerX is offline
Old 06-16-2011, 05:00 PM
  #2937
Potoczak's Avatar
Trader Rating: 120 (100%+)
Hey guys just picked up a tc6 and going to start the build. My question is why do the shocks only come with 2 hole pistons?? I would like to use a 3 hole piston. Can I use pistons from another manufactor?? Thanks for the help!!
Potoczak is offline
Old 06-16-2011, 05:34 PM
  #2938
Verndog's Avatar
Trader Rating: 16 (100%+)
Yes, Losi #57 or 56 work well.
http://www.losipartshouse.com/servle...2357%2C/Detail
Verndog is offline
Old 06-16-2011, 05:41 PM
  #2939
Big Features's Avatar
I use the Two hole pistons and drill them to 1.2mm ea. I also use 40wt oil front and 35 wt. oil rear for med-high bite asphalt.
Mike
Big Features is offline
Old 06-17-2011, 08:29 AM
  #2940
Rick Hohwart's Avatar
There is nothing wrong with two hole pistons.
Rick Hohwart is offline
