Team Associated TC6 Thread
#2911
DOH!
i use the yokomo sway bar things that stop the side to side movement the rear bar had moved and was pushing on the bulkhead causing the tweak
i didnt think about it till after i took the sways bars off and the tweek was gone
thanks for the advice Verndog, it got me looking in the right direction
Ed
#2912
Our TC6's did very good on the track today. Very, very impressive day with my TC6
. Being that I haven't ran onroad in quite awhile, I had a bit of trepidation. I wanted to try the box-stock setup but.....NOT!!
I had the car a bit wider, softer suspension and with PPD Billet and ReflexRacing hopups, I had to try different things.
I must admit, with some of the issues I had building the kit, those things were COMPLETELY forgotten about when the car hit the track. The car felt very confidence-inspiring. My driving was a bit off; but several guys were very impressed with its performance. With the amount of cars in 17.5, I was happy to be 7th in the show. Ended up 7th overall; but this gives me a solid platform to build on. .....now to switch out my current motor to a D3
#2913
I was having a problem with push on med bite asphalt and raised the rear dial-a-grips up .75mm to equiv. of 3A and whola...5 minutes later problem solved! Thanks for the advise Brian...last run MUCH better.
But...2X I got rear body tucked and lost a bunch of time.
I'm going to draft up some rear bumpers, and if I can get them lighter then carbon tower mods, then I'll build a bunch. I'm not throwing away 20 seconds a race to rear tucks again.
#2914
...now I see what the rear bumpers are going on for. I dont remember having this issue with the TC5 so I'm not sure if this is a widespread issue or not.
#2916
#2918
#2920
#2923
Thanks for digging that pic up. One of my concerns is taking a corner hit at an angle, and that doesn't look to protect from that at all...I could be wrong, but dont see how. When I'm getting stuck in the rear, it's corner entry to mid turn when things bottle up and you slow for traffic and the guy behind doesn't...I get tucked and he drives away. Nice dent / mark on my L rear corner at 45 degs. showing the exact point of contact.
#2924
Just got my Dial a Grips.... Look awesome and fit perfect.
One question though. Are you guys using thread lock on the grub screws???
Or is there no need?
#2925
There really is no need, I thread lock them to "factory" block setting with a gage for anyone preferring to leave them there only. It's best to use a feeler gage between block and chassis to set when you adjust them (to get perfect), then use the top set screw to add just a touch of tension after locking down main screw to prevent it from being able to back out.
