Team Associated TC6 Thread >
Like Tree20Likes
Old 01-20-2011, 03:01 PM
  #1516
mugenize1's Avatar
Originally Posted by L.Fairtrace
If anyone is interested in running Xray ECS Driveshafts in their TC6 you can use the TOP spool and these outdrives
The Top spool and these outdrives are a direct fit in the TC6
They are made out of 7075 aluminum.
They can be found here http://sidepieceracing.com
What mm drive shaft would you use they come in different mm for the Xray.
mugenize1 is offline
Old 01-20-2011, 06:11 PM
  #1517
Trader Rating: 23 (100%+)
Originally Posted by rendcool
I don't see any TC6 on in their catalog.
just TC5R ..
Best to phone the store, their site isn't frequently updated.
pcar951 is offline
Old 01-20-2011, 06:35 PM
  #1518
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
They come in two sizes - 50mm and 52mm. You can see pictures of them installed in my Photon on the web site. Hopefully we can test fit this setup in a TC6 this weekend, otherwise it will have to wait until The Birds next week.
hanulec is offline
Old 01-20-2011, 07:05 PM
  #1519
i gots u fat jesus
Jeff Cuffs is offline
Old 01-20-2011, 07:10 PM
  #1520
hanulec's Avatar
Originally Posted by Jeff Cuffs
i gots u fat jesus
thanks Cuffs! bring all of the cars ... we got some photos to take
hanulec is offline
Old 01-21-2011, 01:55 AM
  #1521
daleburr's Avatar
Originally Posted by TJames987
would any of the Herbert carpet setups work for high grip asphault?
The stock "kit" setup did not work at all for the track. So far I went to 0 arm mounts in front and 1 mounts in rear and its better but not great. tips?
Any of Olly Jefferies setups are a good starting point. Moto Arena is probably the highest grip track on the list:
http://www.cmldistribution.co.uk/tea...ter=0000005481
daleburr is offline
Old 01-21-2011, 01:57 AM
  #1522
daleburr's Avatar
Useful TC6 build guide from BRCA champ Olly Jefferies:
http://cmldistribution.co.uk/news.php?view=0000001651
The stuff about getting the chassis and motor mount flat is definitely important. I found the tip about scoring the hubs to remove bearing slop useful as well; even on brand new hubs the bearings move around a fair bit, and scoring them is better than adding superglue.
daleburr is offline
Old 01-21-2011, 10:08 AM
  #1523
Default Lubes in the box!
Hi,
Just a real quickie, are you meant to get any lubes with the kit? I mean like black grease, diff grease?
Thanks,
Carl
carl_Bennetts is offline
Old 01-21-2011, 10:14 AM
  #1524
Rick Hohwart's Avatar
Andrew Abbott's Summer Nats (Australia) setup sheet is now posted.
Rick Hohwart is offline
Old 01-21-2011, 11:48 AM
  #1525
Buckaroo's Avatar
Originally Posted by carl_Bennetts
Hi,
Thanks,
Carl
Yes, you should get the diff grease, black grease for the thrust bearings, and shock oil in the box. If you didn't, you need to call Associated and they'll send it out to you ASAP.
Buckaroo is offline
Old 01-21-2011, 12:13 PM
  #1526
cheehtae's Avatar
Trader Rating: 15 (100%+)
Which setup would be a good starting point for a17.5 non boosted rubber carpet on a small track. Most of the setups online are for mod or sometimes boosted.thanks guys.
cheehtae is offline
Old 01-21-2011, 12:28 PM
  #1527
Mowell's Avatar
I'm running 3.84 with an Ion3 coming off the track at 150 at end of 6 minutes. That's with 0 endbell timing.
Mowell is offline
Old 01-21-2011, 12:42 PM
  #1528
cheehtae's Avatar
Thanks, but I 'm talking about car set up not gearing.
cheehtae is offline
Old 01-21-2011, 01:35 PM
  #1529
Buckaroo's Avatar
Herbert indoor champs. Click here. You can sub #2 pistons instead of the 1/1/1.5s and use 40 weight oil, you can also use 7A as a rear camber link position for starters until you get shorter turnbuckles. +1mm shim with the black ball studs until you get silver ones, too.
Running mine this way. Dialed in pretty close with Sorex 24s on a small indoor carpet track 17.5 non-boosted.
Buckaroo is offline
Old 01-21-2011, 02:31 PM
  #1530
cheehtae's Avatar
Buckaroo, I'l try it. Thanks.
cheehtae is offline
