Team Associated TC6 Thread >
Like Tree20Likes
Old 11-30-2010, 09:24 PM
  #766
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by kid TT-01
Its a straight drop in, you can keep the drive shafts and blades, you will need to dremel a bit though.
So it's dremel rather than a light sanding??
STLNLST is offline
Old 12-01-2010, 02:00 AM
  #767
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Speaking with one of the AE drivers in Aus, he was saying you need to open the out drives a bit more. So drilling a larger penning in the cup. A light sand wouldn't do much. Ill test this out over the weekend when i build my kit up.
A Ilievski is offline
Old 12-01-2010, 05:11 AM
  #768
Trader Rating: 118 (100%+)
Originally Posted by walterhenderson
BD5(mfg. by yok) diff fits, You need to grind the ball of the bone or drill out the cups. the blades fit with just a little sanding. Keven and I ran 80 wt ae oil at the champs.
Are you going to be at MSI on Sunday? Would like to take a look at the gear diff setup. Do you know if AE is working on their own version?
Chris Furman is offline
Old 12-01-2010, 06:56 AM
  #769
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
Any shimming needed or is it a direct drop in like it was made for the TC6? So we can keep the AE drive shafts and blades and just sand the outdrives so the blade fits???
The driveshafts are the same as the tc5 i did not have to modify anything with the spec-r bd5 diff in my tc5.I am getting my tc6 thursday i will let you know that night.
Warren Weaver is offline
Old 12-01-2010, 07:17 AM
  #770
i also have TC5 and consider to buy spec-R BD5 diff.
Please post some photos for your diff in TC5...
Any extra spacers needed?
mos-leung is offline
Old 12-01-2010, 11:07 AM
  #771
Yes a drop in fit. It is snug but to problems
walterhenderson is offline
Old 12-01-2010, 11:08 AM
  #772
No, i have to work.
I don't know
Old 12-01-2010, 12:39 PM
  #773
Buckaroo's Avatar
Anyone else notice that the assembly of the TC6 slipper spool now includes the 5/64" thrust balls on the short side of the diff outdrive? These weren't part of the TC5 assembly. What overall difference would this make?
Buckaroo is offline
Old 12-01-2010, 01:04 PM
  #774
Trader Rating: 84 (100%+)
the thrust balls should prevent the slipper spool from coming loose like the old one did.
jeff jenkins is offline
Old 12-01-2010, 01:44 PM
  #775
twk-b's Avatar
+1
this was never a problem (without the thurst ball assembly) while running 17.5 stock and boosted, but as soon as I switched to 13.5 the slipper was coming undone all the time... when I asked around all the TC5 guys at the track run with the thrust assembly...
-b
twk-b is offline
Old 12-01-2010, 02:01 PM
  #776
wtcc's Avatar
Originally Posted by sosidge
I'm certain it's a typo. Whoever re-typed the setup sheet for the manual misread "-1.5" for "4.5".
Rick Hohwart confirmed that it's a typo. -1.5° is the value that was meant to be there!
wtcc is offline
Old 12-01-2010, 02:06 PM
  #777
Buckaroo's Avatar
There seem to be a lot of typos with the identification of hardware and stock numbers, too!
Buckaroo is offline
Old 12-01-2010, 02:43 PM
  #778
I was going thru the manual part numbers and they refer to all SOFT plastics! Please tell me that is wrong!
Old 12-01-2010, 02:48 PM
  #779
AE-Reedy
Yes it is wrong. All parts are hard plastic.
Sean Cochran is offline
Old 12-01-2010, 02:50 PM
  #780
Alright great! what a relief..... Maybe that manual should be taken down from the site until it is corrected? Are you guys planning on correcting the book and/or PDF?
