Team Associated TC6 Thread >
Like Tree20Likes
Old 12-08-2010, 10:39 PM
  #916
Trader Rating: 23 (100%+)
Originally Posted by tqcookie
Hey guys, just getting the TC6 all buttoned up for this weekends race and have a couple of questions. I am putting Kevin Hebert's Timezone setup on the car and the setup sheet says 3* total toe for the rear. Does this equate to 1.5* per side. Also when refering to arm mount shims, the book says we should have 1mm, 1.5mm and 2mm shims. However, when measured with a calipper none of the shims are actually as thick as they are supposed to be. So on Kevin's setup if it calls for 3.5mm arm mount shims, do you think he is using what is supposed to be 3.5mm from the kit, or another shim that actually totals 3.5mm?
I think Kevin means the blue aluminum shims. I'm using 2mm / 1mm / .5mm RR and 1mm FR. You get a little less than 3 degrees per side (on the Hudy setup).
pcar951 is offline
Old 12-08-2010, 11:37 PM
  #917
rccuba's Avatar
... Also when refering to arm mount shims, the book says we should have 1mm, 1.5mm and 2mm shims. However, when measured with a calipper none of the shims are actually as thick as they are supposed to be. ....
hi, as to the arm mount shims, the book does not tell you that they are 1mm, 1.5mm and 2mm ... but with these washers, once placed, you get 1 º, 1.5 º and 2 º, that bone the unit of measurement are degrees, not millimeters ...
I hope I explained well, my English is not very good .......
greetings from Spain to all ....
rccuba is offline
Old 12-09-2010, 08:20 AM
  #918
tqcookie's Avatar
that makes more sense.
tqcookie is offline
Old 12-09-2010, 09:07 AM
  #919
I run the Alluminum ride height space from 12r5 for the arm mount shims ! I use 1mm and 3.5mm in the rear which is just a bit under 3 Degree of rear toe, and I run 2mm in the front.
Keven H is offline
Old 12-09-2010, 11:27 AM
  #920
wtcc's Avatar
Is it the part #4617 Front Bulkhead Shim?
wtcc is offline
Old 12-09-2010, 11:35 AM
  #921
blackdog's Avatar
Questions?? the diffs
Hi all
quick question.Im building the diffs and have compressed the spring 5 /6 time and the diff thrust bolt wont thread to the nut on the otherside ??? .the spring ,spacer then nut are all present but either way spool or ball they wont go together ???? should I get a big pair of pliers out (LOL) .
I've built so many cars but hope someone can help ,I dont wont to damage anything or have to buy parts already ...
Matt
blackdog is offline
Old 12-09-2010, 11:46 AM
  #922
SkarTisu's Avatar
Originally Posted by blackdog
Hi all
Matt
I ran into this when building my TC5 diffs the first time. What I did was grab my 4mm ball hex driver and use the end of that to press on the t-nut, then pressed hard on the other side with the normal 2mm hex driver, and I was able to get the screw to start threading into the nut.
I think a 3mm ball driver would also work, but I didn't try it.
SkarTisu is offline
Old 12-09-2010, 11:54 AM
  #923
twk-b's Avatar
Hi all
Matt
Everyone laughs when they see my vice grips in my pit bag, but I put the diff spring in vice grip for 30minutes-60minutes before I put the diff together and then it goes together without a fuss.
Make sure to check them for tightness after a couple of runs.
-b
twk-b is offline
Old 12-09-2010, 12:58 PM
  #924
yes
walterhenderson is offline
Old 12-09-2010, 01:13 PM
  #925
Kevin K's Avatar
Trader Rating: 32 (100%+)
Hi all
Matt
I just helped a friend build one this last weekend and he had the same issue. Make sure that the nut is fully seated in the black plastic holder. I used a 3.5mm allen driver to push the nut fully into the black plastic holder. Place the plastic holder on a hard surface and put the nut inside and then press down with the allen driver while pressing on the nut so it fully seats the nut and you are ready to go.
Kevin K is offline
Old 12-09-2010, 01:32 PM
  #926
i1justin's Avatar
Trader Rating: 20 (100%+)
as the others just said that nut needs to be well seated in the plastic, it goes down i would say 3mm at least, so you can see plastic side walls after the nut, if the nut is flush with the top of the plastic its not down far enough.
i1justin is offline
Old 12-09-2010, 02:42 PM
  #927
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by walterhenderson
Yes a drop in fit. It is snug but to problems
Where can I order one of the gear Diff?
ira is offline
Old 12-09-2010, 07:21 PM
  #928
Trader Rating: 118 (100%+)
www.rcmodel.hk
search for bd-500gs
I have purchased 4 from them.. I believe they have more in stock.
Chris Furman is offline
Old 12-09-2010, 07:42 PM
  #929
ira
ira's Avatar
Originally Posted by Chris Furman
www.rcmodel.hk
search for bd-500gs
Thanks for the info.
ira is offline
Old 12-09-2010, 09:12 PM
  #930
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
http://www.driftspeed.com
RAL is offline
