Team Associated TC6 Thread
#1486
I too changed my setup (a Juho copy) to see if it fits me and makes the car faster. The last thing I need was a Mazda-body. It is the first Mazda one I bought. And I hate its design! In my eyes it is very ugly. Now that I worked with it, it is even worse. I normally use the HB 09x. This body is a beauty in comparison to the Mazda. I cannot understand that our aerodynamic bodies look that way. In general good aerodynamic brings also a good look. Why not in our hobby?
So, this is the best what I could do to hide the uglyness. I still try to find my "colours". This time I did an experiment with a lot transparency.
#1487
anyone have the actual sizes (drill or mm) for the kit shocks 1, 2, 3?
I know the losi sizes correspond with drill sizes, 55=1.3mm, 56=1.2mm, 57 1.1mm...
thanks
-b
thanks
-b
#1488
#1489
ok to understand it right,
how much holes of which size do the losi pistons 56 and 57 have?
losi´s are not av here so i have to check for alternatives
greetings
greetings
#1490
I did the math, hopefully without making a mistake, and then put them in order based on total area.
AE/Losi Pistons Chart
54 = blue (1.4) x3 = 4.61811 mm^2
55 = orange (1.32) x3 = 4.10541 mm^2
56 = red (1.2) x3 = 3.39291 mm^2
AE#1 = 54 (1.4) x2 = 3.07874 mm^2
57 = black (1.1) x3 = 2.85096 mm^2
AE#2 = 55 (1.32) x 2 = 2.73694 mm^2
60 = natural (1.0) x3 = 2.35617 mm^2
AE#3 = 3/64" (1.19m) x2 = 2.22438 mm^2
#1493
-b
#1494
I like it!!!
#1495
Hi!
At last Saturday I drive TC6 and it drive like crap!!!
When all is fine it is nice, made me happy bit WTF, I had issues that I never get at tc5r !!!????
- a arms mount made from |------| to this /-----\ and big slop!, plastics move
outside
, no screw issue, I put longer ones, but it looks like blue part
is a little too long ..., and it move outside, I put car on track do 5 laps to
test it and ... it made me really angry, before run I must check it again ...,
outside
The solution is to line the hole in the arm mount with superglue (CA), then allow it to dry for a couple of hours. Then when you fit the bushing it should be a tight fit into the mount, preventing anything rotating.
You also need to threadlock the arm mount screws, otherwise these can come undone in an impact.
Hope that helps!
#1496
I also found they leak making it impossible to get rid of the air (as they just keep sucking in more air around the bottom seals. I've rebuilt the seals and packed them with Vaseline (petrolium jelly - basically the same as Associated's Green Slime) which seems quite a lot better. I may also try changing the o-rings to some TRF ones as the red rubber o-rings that AE supply don't look as soft as the usual silicon o-rings you'd expect in shocks.
#1497
I haven't run the cat yet, but you guys are right shocks are crap.I am planning on replacing them with tamiya shocks.
#1498
little more difficult to build
i like the screw to hold the piston
#1499
I actually think the TC6 shocks are quite good, just as good as tamiya and definitely easier to build then xray shocks.
Mine went together really smooth and don’t leak, I’m surprised people are complaining about the shocks.
The screw in piston makes them so easy to rebuild, I'm happy.
#1500
[QUOTE=azz187;8508263]I actually think the TC6 shocks are quite good, just as good as tamiya and definitely easier to build then xray shocks.
I beg to disagree.
I beg to disagree.
