Team Associated TC6 Thread
#2986
There is also the heavy duty version that is used in the Sakura Zero S (steel outdrives). It is still available
#2987
#2988
Hey guys i'm on the fence. I quite sure which i'm going to go.
no this not a which on is better post lol
Just curious what your guys overall opinion on the TC6 and what would be required to beside some hope up form reflex and ppd billet. products.
what i'm would like to know buy the kit, what is the best thing to do to build it right and do what is necceary to get it done.
my club is 99% xray and I just can't go that route. I really liked my tc5 and time for a new car.
so any info would be great.
oh going to be for asphalt racing.
thanks
thanks
#2989
thanks
thanks
#2990
First of all you do not need reflex or PPD parts. They could be something that you could upgrade in the future but they are not performance upgrades in my opinion. The only option you might consider is a gear diff for the rear and maybe for the front. Team guys like Keven H and I run the cars stock other than the gear diffs.
Which diff are you using ?
Is associated planning to make their own gear diff ?
Thanx.
#2991
thanks
thanks
The PPD Dial-a-grip is a good option to reduce your work after every run and to make fast changes on the arm mounts --> if you race often you will not miss this one.
The shock tower mounts from Reflex are in my eyes not neccessary because the car already offers a lot of positions for the roll center link. Therefore are their springs an enrichement to the Asso range of springs by filling the big lbs gaps in between.
#2992
#2993
#2994
#2998
Using Spec-R Yokomo BD5 Gear Diff for TC5/TC6.
It fits, but the CVD and out drive is tight.
Need to sand off CVD ends a little bit to make room for out drive.
Click here for more information.
FYI.
FYI.
#2999
SPECR DIFF
FYI.
FYI.
Cheers
Ren
#3000
Hey guys thanks for the info.
well looks like I will be going with this ride very soon as long as my finacial advisor is okay with the purchase(aka the wife) lol
my next question is is there any info on building the perfect car,
from the time I opean the box to the momment i place her on the track.
I would also like to find a decent ashpalt stock set up too. to use as reference.
the main reason i'm going this route for is I already have TC5 and some part will slid over. thanks for all you help.
I guess i have to go down to my LHS and order one in.
Damm postal strike
Damm postal strike
