Losi XXX-S
is there a difference when you cut your belt from the black one ????
The Evicerator
They feel pretty close... I'd say a broken in black belt would probably be a little more free than the cut yellow though...
Originally posted by Randy Caster
did everyone sell their XXXS over the weekend or what, where are you guys
Was at Maui for the week...No racin' there.
Looking forward to the next Shootout article for the belted cars in next month's XRC magazine.
Breaking in a new belt
Hey guys,
Just picked up a new black belt kit and wanted to know if i should do anything special to break it in? It seems a bit sluggish right now but im assuming its because it is new.
Thanks,
Blake
Thanks,
Blake
When ever I completely rebuild a drive train with new bearings, belt and everything, or especially a brand new kit, I'll mount a old stock motor in the car and hook it up to my LRP charger at a 2 volt motor run in and put the car on a stand with a big fan blowing on the motor. Let it run for about a half an hour. That's what I do to break in a new drive train.
Geeeze...Something else I should try.
Do you do anything to bring the wheels up to what would be a normal running position? Not too sure that I would want to just let them hang down during break in.
Thanks.
whats wrong with just letting them "hang down"?
unless you got a miniture rolling road you kinda got no choice...unless you take them off
Originally posted by XXX-S Bill
Jon,
Thanks.
Jon,
Thanks.
Otherwise, I could temporarily drop in four long droop screws to achieve normal ride height for the wheels during the break in process.
Actually, a chassis dyno is something I am considering making for multiple reasons. Used them on my formula car way back when to check for drive train issues.
Thanks.
meh, all you need is 4 rolling pins and a box to fix them to...viola a rolling road
I dont have my CVD's hooked up,I am only breaking in the belts.
The car is complete when I do it, shocks and all. So the down travel is limited. Not really at running height but not hanging at full extension either. It's usually the last thing I do before I take it to the track for the first time.
i was racing the other night and snaped a black belt
I've been racing a Losi XXXs for about 18 months. After about 6 months I cut every second dimple on the yellow belt and found that to be a significant improvement for stock racing.
After using the black belt for a couple of weeks I found that cutting it in the same way as I did the yellow belt made the drive train very free and did not lead to to skipping.
AlanC
AlanC
Chazz
