Like Tree2Likes
Losi XXX-S
Old 08-06-2004, 05:08 PM
  #11866
mwcet8k's Avatar
Loosen the two screws slightly that hold each roll center block to the chassis. Once you've completely tightened the pivot block screws, retighten the roll center blocks.
mwcet8k is offline
Old 08-07-2004, 11:19 AM
  #11867
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by Cardboard
What is the trick to getting the 0F block to work with the low roll pivots?
I just had to take a little material off the bumper, and it worked fine.
Randy Caster is offline
Old 08-08-2004, 01:43 AM
  #11868
JayBee's Avatar
Trader Rating: 31 (100%+)
Post NEW STUFF...
I want to get a few new things for my Losi; is the new PRP shock towers and Tamiya shocks worth the money? I'm getting the G+ conversion kit and wanted to know what shocks come with the standard G+ Kit? Are they the same shocks that come with the RTR?
- JaYbEE
JayBee is offline
Old 08-08-2004, 03:44 AM
  #11869
JayBee's Avatar
Post
Who has a website for the Tamiya shocks?
- jAyBee
JayBee is offline
Old 08-08-2004, 08:56 AM
  #11870
Cardboard's Avatar
Default Re: NEW STUFF...
IMO, the tamiya shocks aren't necessary, but, then again, I've always like the stock shocks.
Nope, the G+ comes with threaded shock set, with .36 shafts in back and .28 in front. Theres a full set on ebay right now for about $25 ea.
Cardboard is offline
Old 08-08-2004, 09:57 AM
  #11871
Default JAYBEE
The trinity heat sink is actually a plate w/ fins screwed to the top that gets sandwiched between the motor and the mounting plate. I think what you're looking for is the clamp with the heatsink on it and that is made by dynamite. sorry I don't have the p# for you.
Found it dynamites # is dyn6820
Poppa Ray is offline
Old 08-08-2004, 11:26 AM
  #11872
STLNLST's Avatar
Trader Rating: 32 (100%+)
James- That's messed up that I had to run without my Losi buddy yesterday. Did you stay for any of the qualifying? Did you like that motor? Just call me the taller Jim Dieter.....LOL
STLNLST is offline
Old 08-08-2004, 11:48 AM
  #11873
Yeah sorry I had to go out with some friends last night. If there was more chicks at the track I would have stayed. I stayed for the first round when you had TQ. I saw you motor Jim Rose. It looked good, stayed strong the whole 5 minutes it looked like. I'm Rick James, b*tch...LOL.
James Nguyen is offline
Old 08-08-2004, 12:01 PM
  #11874
STLNLST's Avatar
I The motor actually got better as the night went on so you can imagine what happened to everyone on the straight... I made Lex look like he was running a micro motor. I broke in the main though. The next time out I will bring my brighter painted bodies.
STLNLST is offline
Old 08-08-2004, 06:31 PM
  #11875
Cardboard's Avatar
Hey,
What adjustment should I be looking at for ultra fine-tuning the rear slide?
Sorry about my newbness.....
Old 08-08-2004, 06:47 PM
  #11876
Cardboard's Avatar
Also, do the higher numbered pistons have smaller or larger holes than the lower numbered ones?
Old 08-08-2004, 07:07 PM
  #11877
JayBee's Avatar
Post
CARDBOARD & POPPA RAY
THANKS GUYS
- JaYBEe
JayBee is offline
Old 08-08-2004, 09:04 PM
  #11878
Cardboard's Avatar
Hey,
Never mind. I understand it now.
Old 08-08-2004, 09:05 PM
  #11879
Trader Rating: 16 (100%+)
Then share with us...Pleeeeeeeeze
Still Bill is offline
Old 08-08-2004, 09:11 PM
  #11880
Cardboard's Avatar
