Losi XXX-S
i tried the 90/27 and it just made my motor hotter
R/C Tech Elite Member
its a new motor ran 3 times hoods are right the comm has been centered with a med. brush w 13 oz prings on both side .there doesnt seem to be drag in the car i just put new bearings in the hole car .diffs are smoooth and not slipping i am about to switch to the dark side and get a tc3
Also make sure its not shimmed to tight.
their is a little play back and forth . i have never had this many motor problems in my life but its all for fun right
I dunno. I ran mine 41/128 and it came off the track at 140 degrees after a 6 min run.
do you have a fan on yours
Guy temped it with his gun when I came off the track in the main. it was an indoor track, about 80 degrees outside and humid. My car is super super free though. I think that helps out a ton. I'll have them check it again this weekend and see how it comes off.
Oh and I dont use a fan.
Originally posted by JayBee
REEDY FANS
I just bought one of the Reedy replacement fans to cool my motor a little bit;
REEDY FANS
Originally posted by mwcet8k
Where did you buy it? I've looked around, but can't find a fan that small.
- JaYBeE
Originally posted by Tony Szep
yes there is a heat sink it is from trinity it works real well it cost about 12.00
- jAYbeE
www.stormerhobbies.com
- jAyBEe
I found some @ Stormer Hobbies, part# ASC0448, for $8.95; maybe you have more stuff to order 'cause for the $6.95 S&H, it's not worth it to just get the fan . Maybe you have your LHS order one for you .
- jAyBEe
- jAyBEe
What is the trick to getting the 0F block to work with the low roll pivots?
