Losi XXX-S
#9153
Trader Rating: 32 (100%+)
Kraig...you rock....and your site and service cant be matched in my book..... PM me when you get just a black belt in with out the hardware.
Racer-OZ.....here is a link to the JETT racing adapters....they offer a 23t and a 24t pulley. I run the 24t it frees up the drive train a little more and these pullies are the best out there IMHO. The trinity one is a P.o.S. http://shopping.rcmodel.com.hk/index...a&filter_id=71
#9154
xxxs shock springs
Can somebody please tell me all thespring rates by weight and color please for all losi xxxs shock springs thanks in advance
#9155
Re: xxxs shock springs
#9156
Originally posted by racer-oZ
Hey xxx-s faithfuls. Are most of you running the blue 64 pitch losi gear or have you gone to the pulley adapter that allows you to run other branded spur gears? If anyone knows which is the best pulley adapter put the link here so I can check it out.
Thanks!
racer-oZ
Thanks!
racer-oZ
i now use the 128 kevlar spur gear, same as the blue one... i personally prefer the losi ones, over the pulley adapters, although there's a new adapter, that's a whole lot lighter than the alum ones from trinity.
#9158
The Evicerator
To anyone racing this weekend up in stockton... I hope to see you all there on friday
And also a quick question... do they sell the TQ tire sauces there or am I gonna have to track them down before I go...
#9159
I got you covered Evicerator if they don't have it there.
#9161
thanks jits..
have anyone tried with the xxx-s, negative (hub carrier lower then chasis line) droop. what say you?
#9162
Beginner XXX-S G+
I just started playing with my new xxx-s g+. and need some tip which will help me to make my car roll smoother. .. and longer.. i play in car parks.. and smooth track..
and using a monster pro.. trinity stock. and using 23t pinion..
can some one give me more tips on this car..
#9163
Remove the grease from the bearings. Remove the bearing sheild from one side of all bearings that are exosed to the elements and remove both sheild from those that are not.
Cut off every-other tooth from the drive belt.
I would start with those items.
E
E
#9164
R/C Tech Elite Member
Originally posted by lozi
thanks jits..
thanks jits..
#9165
Run the belt as loose as possible, it should skip 2 or 3 teeth under HEAVY braking
