Like Tree2Likes
Losi XXX-S
Old 03-08-2004, 09:04 PM
  #9151
racer-oZ's Avatar
Hey xxx-s faithfuls. Are most of you running the blue 64 pitch losi gear or have you gone to the pulley adapter that allows you to run other branded spur gears? If anyone knows which is the best pulley adapter put the link here so I can check it out.
Thanks!
racer-oZ
racer-oZ is offline
Old 03-08-2004, 09:12 PM
  #9152
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Hey guys thanks for the kind words. I try to do my best to make everyone happy. Just make sure you use the big pulley with the sedans.
Kraig is offline
Old 03-08-2004, 09:53 PM
  #9153
Kevin K's Avatar
Trader Rating: 32 (100%+)
Kraig...you rock....and your site and service cant be matched in my book..... PM me when you get just a black belt in with out the hardware.
Racer-OZ.....here is a link to the JETT racing adapters....they offer a 23t and a 24t pulley. I run the 24t it frees up the drive train a little more and these pullies are the best out there IMHO. The trinity one is a P.o.S. http://shopping.rcmodel.com.hk/index...a&filter_id=71
Kevin K is offline
Old 03-08-2004, 09:54 PM
  #9154
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
Default xxxs shock springs
Can somebody please tell me all thespring rates by weight and color please for all losi xxxs shock springs thanks in advance
Dave Bowser is offline
Old 03-08-2004, 09:57 PM
  #9155
Default Re: xxxs shock springs
http://www.teamlosi.com/techtips/spring_chart.htm
James Nguyen is offline
Old 03-08-2004, 10:05 PM
  #9156
highwayman's Avatar
Thanks!
racer-oZ
i now use the 128 kevlar spur gear, same as the blue one... i personally prefer the losi ones, over the pulley adapters, although there's a new adapter, that's a whole lot lighter than the alum ones from trinity.
highwayman is offline
Old 03-08-2004, 10:08 PM
  #9157
STLNLST's Avatar
Originally posted by Randman
As long as I dont fall through, it'll be cool with me. What happened to it? You be there Friday?
what happened to what???? I'll be there on Friday. I'm looking to get some good testing in on Friday and maybe one quick run on Saturday.
STLNLST is offline
Old 03-08-2004, 10:48 PM
  #9158
The Evicerator
To anyone racing this weekend up in stockton... I hope to see you all there on friday
And also a quick question... do they sell the TQ tire sauces there or am I gonna have to track them down before I go...
Steve Weiss is offline
Old 03-08-2004, 10:52 PM
  #9159
I got you covered Evicerator if they don't have it there.
Old 03-09-2004, 12:15 AM
  #9160
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Sounds like a bunch of SoCal guys are gonna be at the race this time
I just finished mounting the Alfa up on the new Losi, so I'll be running it at SoCal tomorrow.
Steve, if you need TQ sauce, I have it.
Randy Caster is offline
Old 03-09-2004, 02:15 AM
  #9161
thanks jits..
have anyone tried with the xxx-s, negative (hub carrier lower then chasis line) droop. what say you?
lozi is offline
Old 03-09-2004, 05:10 AM
  #9162
Beginner XXX-S G+
I just started playing with my new xxx-s g+. and need some tip which will help me to make my car roll smoother. .. and longer.. i play in car parks.. and smooth track..
and using a monster pro.. trinity stock. and using 23t pinion..
can some one give me more tips on this car..
liteoffire is offline
Old 03-09-2004, 08:11 AM
  #9163
EricF's Avatar
Remove the grease from the bearings. Remove the bearing sheild from one side of all bearings that are exosed to the elements and remove both sheild from those that are not.
Cut off every-other tooth from the drive belt.
I would start with those items.
E
EricF is offline
Old 03-09-2004, 08:59 AM
  #9164
Originally posted by lozi
thanks jits..
That's just going to give you a lot of droop, more than necissary for anything short of off-road. You'd also have to lengthen your shocks just to allow that kind of droop.
Old 03-09-2004, 01:22 PM
  #9165
Run the belt as loose as possible, it should skip 2 or 3 teeth under HEAVY braking
Poppa Ray is offline
