Like Tree2Likes
Losi XXX-S
Old 01-18-2004, 11:10 PM
  #8521
Regional Moderator
Addict sa RC's Avatar
Originally posted by proudwinner
XXX-S owners let me pick your brain, I have a friend that has his diff loosening up on him after every run, can anyone relate to this and post what the problem is? He swears he built the diff correctly and it only has approximately 4+ runs on it.
Things to check:
1. Are the concave washers complete? (there should be 6)
2. Are they on the right way? (curved part should be facing the locknut)
3. Is the locknut still good? (The nylon part might have stripped)
Anything else that I might have overlooked guys?
Addict sa RC is offline
Old 01-19-2004, 12:27 AM
  #8522
JitsuGuy's Avatar
Dag-blasted offset hubs and camber!!! UGH!!! I just put some offset hubs on and now I can't get -1 degree camber without the turnbuckle wanting to punch through the dag blasted son of a gun ball cup! AHHH!!!
Okay, so now what brainiacs?
J
JitsuGuy is offline
Old 01-19-2004, 12:33 AM
  #8523
Uhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh Dremel:lol
ZER01 is offline
Old 01-19-2004, 12:35 AM
  #8524
JitsuGuy's Avatar
Dremel? Dremel what? I tried cutting the ball cups down, all that does is give me less material to thread the ball cup on with.. If you're talking about dremeling the turnbuckle down... You're CRAZY man!!!
J
JitsuGuy is offline
Old 01-19-2004, 12:41 AM
  #8525
No MAN! Man you know what I'm talking about, dremel the arm, either that or you could dremel the antenna mount(however the hell you spell it) which inturn with give you lower downforce. After that though i found that counteracts body height so you might want to lower you body......SirJitsu my masta, dremel a tad off the end of the hub, just a tiny bit off the corner, don't dare touch that ballcup or I will make anotha trip out there runnin through your tolls.. Man tell Randy I said I think he did great at the Novak race, he's faster than what he thinks.
Jesse
ZER01 is offline
Old 01-19-2004, 12:47 AM
  #8526
JitsuGuy's Avatar
Dude, I have absolutely no idea what you're talking about! LOL... I don't need no stinking downforce, I need to be able to shorten the camber links or something so I can run these blasted offset hubs with -1 degree camber.
Oh, and I'll tell Randy you said he sucks.
J
JitsuGuy is offline
Old 01-19-2004, 12:55 AM
  #8527
Alright jitslu, the fun is now over, sorry for the runaround, are you saying that your turnbuckle is too long to acheive negative stinking one degrees of camber? or are you saying that when the chassis rolls to whichever side that the ballcup interferes with the hub cause yes this will happen running the lower stock holes on the losi rear tower and the in-line(outer hole) camber link hole on the offset hub. To correct this you will need to dremel a lil portion off the offset hub so that this will not ever ever reve happen again.
ZER01 is offline
Old 01-19-2004, 12:58 AM
  #8528
JitsuGuy's Avatar
I wonder if this means I can't run it with the camber link in the same hole it's currently in, in the shock tower. But I don't want to move it in... The car is soooo hooked up... *cries*
JitsuGuy is offline
Old 01-19-2004, 01:00 AM
  #8529
Man I'm crying too, crying that I don't have that opportunity to race at such a nice track as the one you have...so which is it on the questions? Yes you car is fooked up!
ZER01 is offline
Old 01-19-2004, 01:05 AM
  #8530
JitsuGuy's Avatar
Yeah, we're pretty lucky. I'm going to go to Losi's website and see what the team drivers are running with the offset hubs.
WORD TO YO MUTHA!
J
JitsuGuy is offline
Old 01-19-2004, 01:10 AM
  #8531
I'll let her know, thanks for the nice words. Let us know how to fix this problem that we have no clue what you are talking about-take care.
ZER01 is offline
Old 01-19-2004, 01:40 AM
  #8532
babytoy101's Avatar
Talking plastic chassis XXX-S!
hey guys do you have any info on how to lightened the plastic chassis of XXX-S, its heavy! i cant buy Graphite chassis cuz i have to budget what im earning! thanks and hope to hear from you people!
babytoy101 is offline
Old 01-19-2004, 01:58 AM
  #8533
Lightening up is nothing but taking weight off the chassis and that's only accomplished by removing material from the chassis which I wouldn't recommend as the stock chassis is quit flexible and if you lighten it by removing too much material from it you could make it too flexible which would cause an abruptly handling chassis that could lead to breaking it.
ZER01 is offline
Old 01-19-2004, 09:55 AM
  #8534
Jitsu- Depending on what camber locations you run you may need to get shorter links. if you go from all the way long to all the way short there is no way the same link will adjust that much.
ChadK is offline
Old 01-19-2004, 09:59 AM
  #8535
The Evicerator
take a cut off wheel and your dremel and shorten your turnbuckle a little bit... if you're not comfortable with that... I'm sure your local hobby shop stocks slightly shorter turnbuckles
Steve Weiss is offline
