-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
sands 11-25-2003 01:43 PM
Anybody run the new IRS 1/12th caster blocks? Opinions?
davidl 11-25-2003 03:25 PM
I have been using the IRS caster blocks since the last Snowbirds race. You can adjust roll center, reactive caster, camber, caster, and caster gain. I would say it is the most adjustable suspension, probably equal to the Trinity. It uses the Associated lower A arms and spindles from the dynamic strut, but does not have the same issues with caster. IRS has some neat little nylon spacers for caster adjustment than don't deform in a crash. It stays consistent, even through hard hits. It is currently available on the IRS website. I suggest also using the IRS king pins. They are super easy to use.
Mike D 11-25-2003 04:10 PM
Re: 1/12th Arbor
Originally posted by Geppetto
Mike D: You're kidding!?!? Hopefully Mimi has another, or can get one soon. BTW, did you tell me on Saturday that you bought an Ofna tire lathe?
Geppetto - Yeah, I got an Ofna lathe. The Ofna arbors are awful. The Hudy arbors are a direct fit and work real well.
stormperson 11-25-2003 04:15 PM
on the SM tubes... I guess my track's boards arent rough enough, or i am not trying enough, lol.
DavidL- You are going to be in Cleveland right? Do you know if IRS will be selling those castor blocks (12th scale) there? I defently want to pick a set up.
70mph pan car 11-25-2003 04:46 PM
i just got a good deal on some rear green tires and grey fronts. I am very new to 1/12th cars and am just wondering if i will have a problem driving with these tires. is this a bad combonation? I am running on a very short carpet and am using a 12l3 with a p2k2 motor.
70mph pan car 11-25-2003 04:55 PM
http://24.65.250.89/nascar/Images/Co...Carpet_003.jpg
what is the best gearing on this track when using a 12l3 with a p2k2. I don't really care about rollout and such just yet. A rough estimate for gearing would be nice.
What is the difference between 48 and 64 pitch for gears? Is there an advantages over the other to using?
stormperson 11-25-2003 05:06 PM
I would start with a 30/100 with 64 pitch. The reason guys run 64 and not 48 pitch with onroad is because you can adjust your gear ratio to a more exact extent. Also it is smoother and less drag (most likely, and to what extent is arguable). That track is actually a pretty decent size and seems to have a very fast layout for most carpet tracks.
cracked123 11-25-2003 05:10 PM
ya know if you actually asked the guys who race on this track you'll get better results.
:nod:
safaridog 11-25-2003 05:11 PM
that track is 95'x 48'
70mph pan car 11-25-2003 05:18 PM
do you race a 1/12th cracked? if so what do you use?
Korey Harbke 11-25-2003 05:45 PM
Originally posted by sands
when was the last time you cut your comm? light springs on a not-round comm will kill efficiency as the brushes skip.
I'd also suggest running putnam brushes on an epic motor.
I cut the comm every 2 runs (only needs a super light skim). I'll try the slot, has anyone experimented with narrowing the faces of the brush yet? What is the benefit of this?
-Sushi Boy
Adam Hartzell 11-25-2003 05:48 PM
Sushi Boy--I just shave off the trailing edge and leave the rest of the brush.
stormperson 11-25-2003 05:52 PM
narrowing the brush can help with glitching (sometimes) and also reducing amp draw.
ultragraffics 11-25-2003 08:54 PM
Also dont forget about the new Orion V2. I have heard alot of good results. I saw JP reunning one in offroad. Looked very smooth and seemed to have very little comm wear as expected. Alot of the guys are filing the brushes down...
Korey Harbke 11-25-2003 10:16 PM
How much do you shave off exactly?
-Sushi Boy
