I polish my hinge pins and king pins to a mirror shine to get that free movement. If they are still binding at that point a quick run in the dremel with 2000 grit then another polish gets the job done.
Originally Posted by vafactor
(Post 13969416)
In the recentlly posted kingpin shimming video, the upper arm on the car that's being used for illustration is clearly too tight. In order for the front suspension to function at its best, the upper arm should pivot on its hingepin freely enough so that it will drop down just by its own weight. Possible (and typical) causes for the upper arm binding are: the hingpin itself often fits too tightly in the upper arm. Either that or else the stack of caster shims may be slightly too thick. Both are common problems on 1/12th scale cars, but thankfully both are fairly easy to address. To free up the hingpin, just run the appropriate size reamer or pin-vise drill bit thru the plastic upper arm, opening up the hingpin holes just enough to allow the hingpin itself to slide thru freely but still without any slop. To eliminate binding from the caster shims, you can rub just one of the little shims per side on an emory board or fine sandpaper to reduce it's thickness slightly. Remove only enough thickness so that the stack of caster shims can slide into place without binding the upper arm. Once the hingpin fits nice and the caster shim stack has been adjusted to yield the correct dimension, the assembled upper arm should drop nice and free, without any binding, and also without any slop or excessive play.
Keen eye you have :) I did this on purpose so the arm wouldn't be flopping around during the kingpin demonstration videos. Thank you for providing a nice detailed explanation on this matter :) Do you mind if I use your detailed description in an upcoming video? Cheers. |
Originally Posted by EDWARD2003
(Post 13969478)
Picked up a CRC Altered Ego for myself…now the question is, run our spec 21.5 class with my son or step up to 17.5. I have been running VTA, but it is weak around here. Hmmm.
Originally Posted by stigsdad
(Post 13971799)
I think I'll pick up the 17.5 and try both…see which better suits my reaction times (or lack thereof)
As long as you run different classes you never have to worry about him beating you ;)
He is six, but it'll happen soon enough. :-)
Six and he can already handle a 1/12 21.5? Wow that's impressive!
Originally Posted by InspGadgt
(Post 13972236)
Hell I still can't go a whole race distance without crashing :)
Oh, neither can I--we're both learning I should say. That said, I really liked sorting out his older CRC and thought….hmm, this might be more fun than a TC. It felt like a Miata rather than a Camaro on a twisty road course.
http://www.teamassociated.com/news/l..._LiPo_Battery_
If anyone is looking for something different. The new Reedy 3900 mAh shorty 7.4 lipo would be worth trying in your 1/12th scale with a 21.5 motor. The dimensions and capacity are identical to what we run here in Japan. Worth a try :nod: |
Thanks for the videos. they are super helpful. looking forward to trying out what I have learned
Nick K |
Glad these videos are of some assistance to you.
Please note: I am no professional with running 1/12th scale vehicles (2 years). The videos and ideas are simply loose guidelines and techniques to follow. By all means use them, but, you or someone you may race with might have a better, faster, simpler method or technique. :batman: |
| All times are GMT -7. It is currently 01:42 AM. |
