-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
EDWARD2003 04-13-2015 05:50 AM
Originally Posted by dr_hfuhuhurr (Post 13957259)
People actually do this? That's hard core!
Every time, buddy.
howardcano 04-13-2015 05:52 AM
Originally Posted by Juniorabca (Post 13956788)
What teeth count did you use? 24tpi or 32tpi?? I have one of these types of truers and am thinking this might be time to replace the one in it as I don't know the age..
The hacksaw blade I'm using has about 24 teeth per inch. I didn't choose that because I know it to be best-- it's just what I had laying around. Hopefully Mr. DuVerney will let us know what he is using.
A properly hardened blade can be easily broken into short, usable pieces by clamping it in a vise and whacking it with a hammer. MAKE SURE YOU WRAP THE BLADE IN A RAG AND WEAR EYE PROTECTION WHEN DOING THIS!!!
InspGadgt 04-13-2015 10:32 AM
Or just cut it with a Dremel
howardcano 04-13-2015 10:45 AM
I find the hammer to be more gratifying. :)
wingracer 04-13-2015 03:05 PM
If you can't fix it with a hammer, you have an electrical problem.
Juniorabca 04-13-2015 07:16 PM
Thanks for that.. I too will use the dremel method to shorten a blade..
patorz31 04-13-2015 08:51 PM
You'll have more fun swinging a hammer....lol
Josh-n-ya 04-13-2015 10:49 PM
...and if that doesn't fix it then you need a bigger hammer! :nod:
EDWARD2003 04-15-2015 07:36 AM
https://m.youtube.com/watch?v=hm7z1r...ature=youtu.be
How to glue 1/12th tires :)
Mach10_shooter 04-15-2015 09:36 AM
Great video. Thanks for posting.
DMALMAD 04-15-2015 01:06 PM
+1
EDWARD2003 04-15-2015 05:20 PM
I'm glad these videos are of some use to you.
In the next video I will demonstrate how to true down and add a nice radius to the tire. I will also point out a few things to keep an eye out for when truing your tires. :sneaky:
Dan the Man 04-16-2015 01:42 AM
Excellent, I just bought a truer :D
The videos are great, please keep them going.
EDWARD2003 04-16-2015 05:01 AM
1 Attachment(s)
Finished product from my "How to true 1/12th and 1/10th foam tires" video.
It's 24 minutes long but it has some good information in there. Keep in mind it was done in one take so I might have muddled up a few words. Besides that, I hope the video is helpful to those using a tire truer for the first time. :nod:
Below is a picture of the finished product. :)
https://m.youtube.com/watch?v=8wqHOL...ature=youtu.be
If it hasn't loaded up yet just give it some time. It's quite a large video file.
heretic 04-16-2015 07:18 AM
First viewer ! :)
Nice video. I have never used a truer but I have cut my fair share of comms so I can relate.:lol: Random comment: You understandably insist on not relying on the markings for actual measurement but just for reference. What about using a plastic or metal cylinder with a known diameter to calibrate your tool placement ? Then you could rely on the graduation. It seems like it would save you a LOT of time, and you could just use the calipers at the very end as a double-check. Anyway. Thanks for taking the time to shoot this ! I will put it to use... one day.
