Originally posted by speedxl :D mike d i trying to find out what the street price is for the conversion kit would you happen to have an idea? |
mike i got your p m i appreciate you help iam just dissapointed with yokomo support . i dont whant to show up to the snow birds and be out to lunch on the carpet. the car is good on asphalt but of course the yoky wasnt designed for carpet. ive heared it wasnt going to be released . just a car that was designed for
masami. |
Originally posted by Fiddle Fadel SpeedXL You might consider getting the IRS Rugrat conversion for your Yokomo. Thats what I did with my Yokomo. I had my local Hobbytown get the kit for me. $85. you can see the conversion on the IRS site. Dave @ IRS is also in the process of making the adj. front AE conversion in 12th scale. This will make a very adj. front suspension. Also with the IRS Rugrat you can run the car as a T-plate or side damper/spring set uo. ( similar to a CRC 6-Pack, but a dedicated 4 cell chasis and adj. battery postions.) A very nice Conversion. Dave |
speedxl-I can get you an IRS RUGRAT as I am an IRS dealer. E-mail me if your serious and I'll get you a price, and date of shipment.
Ray |
Originally posted by racerdx6 Would it be possible to use the IRS conversion kit on my Carpet Knife?? ... |
The Pivot socket is just the thing that goes on the carbon fiber "foot ball" shaped piece right? But on the carpet knife you have to cut the pivot socket down on the sides so it clears the battary and motor. And the pivot balls are just the same as the pivot balls that came with my carpet knife right? They're about 1/4" in diameter? The pivot balls that came with the carpet knife are the same as the pivot balls that I got to convert my car to speed merchent side links.
So I'm considering doing the conversion for my carpet knife. But I want to give the car more of a chance, I'm waiting for some nice new battaries to come in and once I get the new battaries and the new carpet comes, than I'll work with the car a lot more to get it working better. Thanks for the help. |
Oh yeah, does anyone know the web address for IRS's web site?
racer dx mike is right youll pretty much need every thing except for axle assy, pods and shock. that pretty much what you will need if you want to convert to running a t plate car, or just buy a complete car like 12l3 and just buy the bottom plate.
thanks davidl
racerdx- those are not very fragile parts you are breaking, or at least from what I have seen (I would imagine that you would crack wheels, or the main chassis or something before you broke that stuff, even the axle... go figure... lol). A T-bar is much more likely to break, and its pretty much the same exact stress point as the football pivot thingie that you are breaking. Also the pivot balls on a t-bar are different (they have flanges on each side, similar to the ones on the front of a dynamic strut front end).
Also, new batteries will not help solve that situation, it will problem make it worse. New carpet might, however I am doubltful. And, while it might be a handling problem that you are facing, there isnt much that you can be off with a 12th scale, its pretty much the same set up everywhere give or take a few things, but nothing that should make it feel undriveable (unless you go from asphalt to cleveland, however thats hardly the case here). What it comes down to is that, when you hit something there is a chance that you will break. When you hit something hard enough the energy has to go somewhere, and something will most likely break or warp or something. A t-bar car will be much more likely to break than a sprung car. Except for the case of the yok (which masami had specially made for the worlds in '01), most cars can be made to work, espically in stock. So pick a car stick with it, and learn to make it fast, and with a 12th scale as I was saying above, there is normally one basic set up that works pretty decent at most club racing carpet tracks (give or take some 10-20 weights of oil, a rate of spring, etc...), but a car should not be out to lunch. If it is normally its something else is wrong with the car... tweaked, mis-adjusted side links, binding in something, etc... (and learning how to get rid of all of those problems takes time and expeariance). |
Does anyone know if the IRS front end parts will be coming out? I saw prototype parts at Cleveland last year, but I heard Dave was not going to make them due to cost ..Is this true?
racer dx i run a yokomo yr12 and it runs very good in stock these cars can take a beating more so than any touring car ! except for an hpi car, man the kids can beat them to death and they run forever. but anyway sounds to me that you might be doing something wrong during assembly or your trigger finger stays full noodle when your car is driving fast straight into the wall . all cars once set up only require small adjustments once youve found the basic setup that works for you. granted there are some situations that are very rare and requires wierd adjustments. some cars like mine no matter what you do to them wont work in certain situations like mine that the chassis is to thin to run on carpet because it has flex built into it for asphalt.
Originally posted by stormperson racerdx- those are not very fragile parts you are breaking, or at least from what I have seen (I would imagine that you would crack wheels, or the main chassis or something before you broke that stuff, even the axle... go figure... lol). A T-bar is much more likely to break, and its pretty much the same exact stress point as the football pivot thingie that you are breaking. Also the pivot balls on a t-bar are different (they have flanges on each side, similar to the ones on the front of a dynamic strut front end). Also, new batteries will not help solve that situation, it will problem make it worse. New carpet might, however I am doubltful. And, while it might be a handling problem that you are facing, there isnt much that you can be off with a 12th scale, its pretty much the same set up everywhere give or take a few things, but nothing that should make it feel undriveable (unless you go from asphalt to cleveland, however thats hardly the case here). What it comes down to is that, when you hit something there is a chance that you will break. When you hit something hard enough the energy has to go somewhere, and something will most likely break or warp or something. A t-bar car will be much more likely to break than a sprung car. Except for the case of the yok (which masami had specially made for the worlds in '01), most cars can be made to work, espically in stock. So pick a car stick with it, and learn to make it fast, and with a 12th scale as I was saying above, there is normally one basic set up that works pretty decent at most club racing carpet tracks (give or take some 10-20 weights of oil, a rate of spring, etc...), but a car should not be out to lunch. If it is normally its something else is wrong with the car... tweaked, mis-adjusted side links, binding in something, etc... (and learning how to get rid of all of those problems takes time and expeariance). |
marvi/mike d: thanks for the info. :)
marvi: i'll check out giocamoto, maybe over the weekend. i hope they still have it in stock. hopefuly i'll be back into 12th by mid-Sept. lets organize a race soon. |
| All times are GMT -7. It is currently 12:24 AM. |
