-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
70mph pan car 01-31-2003 10:22 AM
y is the rc12l chassis white? is there any advantages to the rc12l3 if u plan to on road bash?
dtm 01-31-2003 11:53 AM
Shooters 1/12
1 Attachment(s)
Originally posted by dtm
There are two local companies in Hong Kong making 4 cell chassis for the RC12L3...one is Top and one is Shooters....The Shooters chassis is almost a copy of the Yokomo chassis, they are also making enough other options to build a "Shooters" car! Of course...much cheaper! I'm putting the latest option on my car- alloy bulkheads...will have pictures to post soon!:D
OK, here are the pics I promised.....
The options I have on it are;
Shooters:
Chassis- all graphite pieces
Alloy damper post
Lower Motor mount and left bulk head
A-arm upper hinge pin (e-clips)
Alloy front body posts (for VoneRR!)
Front ride height shims
Front Axles
Yokomo:
Right rear wheel hub
AE:
Blue Shock body
Blue left rear wheel hub
Blue stand offs
Not much left of the original RC12L3 really!:D :D
1 Attachment(s)
Close up of the rear pod...
dtm 01-31-2003 11:54 AM
1 Attachment(s)
Another view......
dtm 01-31-2003 11:55 AM
1 Attachment(s)
Front view.....
The front height shims are neat...only have to loosen the A arm screws and slide in...or out....
dtm 01-31-2003 12:00 PM
Originally posted by petenis
Kiyano, dtm or any one who knows: Where would I get the Shooter's chassis, If it's worth it? Is there a website or anything?
-Pete Simons
Hi Pete, you can try Control Centre or Harmony Models...both should have stock and do mail order...
http://controlcentre.rctech.net
http://www.yp.com.hk/hecharmony/
kiyano 01-31-2003 03:41 PM
petenis,
Also you can see optional parts for RC12L3 from
here .
The chassis is not sold from this manufacturer:sweat:
dtm,
Is there a webpage of the manufacturer which makes the chassis?
trackdesigner71 01-31-2003 05:56 PM
Whaddayall think of my Bentley idea
dtm 01-31-2003 09:59 PM
Originally posted by kiyano
petenis,
here .
dtm,
GPM is somewhat a "laughing stock" in Hong Kong...no serious local will buy from them.......notorious for poor quality, soft as cheese alloy and parts that don't fit too well......
Shooters don't have a website. Their quality is a lot better, although they did manage to screw up this batch of graphite chassis, the chamfers were cut at the wrong angle!:rolleyes:
70mph pan car 02-01-2003 03:15 PM
i have a jr standard servo and small reciver that i plan to mount on my servo to save space when i get my rc12l3. will a standard servo with dimension fit (o.76 by 1.51 by 1.48) i think that is it. if not what is a cheap servo that will fit.
trackdesigner71 02-01-2003 03:42 PM
1 Attachment(s)
Here is a pic of the real Bentley. My idea is that if you took some music wire, and reamed two small holes near the spoiler, and then ran the music wire through the two holes and then mounted a touring car wing on there, it would look more like the one they race in real life. The music wire could be mounted in the T bar in the rear. It may not be the greatest idea, but its an idea
RC Paperboy 02-01-2003 09:28 PM
Wouldnt that just make the car slower?
darnold 02-02-2003 01:02 AM
Stevie- After Concillian's great answer all i would say is that
SMC GP 3300's are great along with many others such as Trinity GP's and Pro-Match GP's. Try a pack for practice and when they become legal race them. They keep their numbers much longer than we experienced with HV's so you will like that as well. I think you guys can get SMC's over there.
Petenis- I'm looking to come up in two weeks to practice what day is the race day and do you think Yari and Mitch will run 12th mod with me (or anyone else for the matter)? How's Dave, the racing and the drag car btw?
Switchblade- You have an excellent car and should be very competitive with it without needing an immediate upgrade. I do think the 02' edition transitions a little faster but i'm told that your edition is a little more stable with a little more rear traction. Trinity i believe makes a conversion kit for your car to the 02' version so you can contact them about that.
70mph Pan Car- I think you would be much better served by getting the JR Z3555 servo for $60. They last an incredibly long time and are very accurate. The servo you are talking about probably isn't as fast as you need even if you can make it fit and the resolution of the Z3555 may be better especially since it's ball bearing. The Z3555 may also have a coreless or at least 5pole motor, either of which is better than a 3 pole which the standard servo may be which increases resolution and speed.
RCsilly 02-02-2003 03:53 AM
DTM,
Your car is SWEET............. but the purple screws gotta go . :D
RC Paperboy 02-02-2003 05:43 AM
I raced the 1/12 last night, had a great time. I hadd a few problems though. My rear axle bearings, one of them seized, and two got crunchy. I replaced them with some cheap bulk bearings from the shop, but eventually I wantto get some decent ones. Any thoughts on where to go for good, cheap bearings?
I also broke a rear wheel. How should I prevent this? I know the obvious answer is "dont hit stuff".I was thinking of something more along the lines of nerf wings. Any thoughts on this?
And the same with the front, I havent broken a wheel yet (knock on wood), but should I be making a front bumper? I have plently of old TC3 bumpers, made from Kydex, should I cut up one of those?
