For those of you that have been using the odourless (Jack the Gripper etc) how long have you been applying it before the race, and when have you been wiping it off??
Cheers |
Originally posted by racerdx6 I have to say that getting the rear ride height adjusters on the carpet knife to fit is the biggest pain in the ass. It took me like 10 minutes to get them to fit because I kept having to sand them down and than check em so I didn't make them too small. But otherwise the car is working great. It seems like the front tires wear out faster than the rear tires. I thought the rear tires would wear out faster because of how much softer they are. But it looks like the front are wearing faster. |
1/12 SCALE F1 BODIES
HEY GUYS..For those who has been running 1/12 for some time, have you seen 1/12 SCALE F1 BODIES? :tire: and if so where can i get one?
Thank's R/C Paperboy :) ! I will try that, so to get more steering you can stiffen the center spring, right? But when you stiffen the center spring, you also loose some rear traction. But when you run with caster, you car tends to push more right? So if I got rid of the 2º of caster that I'm running I would eliminate some push right? I could also try softening up the front springs, I'm running the 22's in the front right now because that's what came with the kit. I might try some 20's. I don't want to lose any rear traction if I don't need to, so I think the first thing I'm gonna try is softening the front springs because that wouldn't make me lose any rear traction would it? Does anyone have any ideas on this? Thanks :)
:) For more High Speed steering Stiffen the center spring :)
I have my dual rate set around 3 , make the chasis do the steering. You wil have more control. Kit comes with .018" springs. Check them with a dial caliper. What center spring are you using now? Don't worry about the caster. It won't make that much of a difference. What are you running for tires? Kit? David Root |
trueing front tires
I just bought a Hudy tire truer. I have the 1/12th and 1/10th arbors but my Jaco fronts won't fit either arbor. My BSR fronts fit the 1/10th arbor. What arbor do I need? Other advise?
newracer-this sounds really bad-but you need to either force the wheel on-or-turn on the truer and push the wheel against the arbor and it will thread itself on.
One last resort that I have never tried is to drill out the rim with a drill bt the same size as the arbor's threads. Sorry-as I am sure these are not the answers you were looking for. On the biright side-I have never bent or broken a JACO front rim doing these shadetree methods!!! |
do I then need to use flanged bearings? not a problem since I have them.
newracer-Jacos use a non-flanged bearing. TRC uses Flanged.
newracer-
only drill out the center to the same size as the arbor threads, do not completly drill out the bearing stops. But if you did/do then yes you will need to use flanged bearings. Eric |
Originally posted by stormperson graphitedust- I assume you are the track you are talking about is Socal? That seems kinda small for a 8x1 for 12th scale. I would go to a 9 or 10 double, you will have slightly less torque and thus more runtime. maybe even try an 8x3 or 4 and gear it more agressively. also pick up some 3300's, that should help you out alot as well. and if that doesnt work try a reciever pack. 1 - go up in winds, say to a 10, and also go with a more aggressive timing to get the power I'm looking for. or 2- go with a lower wind, like a 7x1, and use less timing. At any rate, I think I'm looking at buying some 3300's for this car. Is 8 min run time still an issue for you real 1/12 scale guys running 3300's? |
hi guys, trying to start into 1/12... maybe into a RC12L3....but wat are the brands of tyres suitable for the car???
and anyone got the website for TRC tyres?? thanx |
Originally posted by IMPACTPLAYR 4- If you would run an 8 min. race you would probably go with less motor and much more conservative timing... |
newracer-sorry-missed the "then do I need" part.....
| All times are GMT -7. It is currently 07:11 PM. |
