Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-29-2007, 08:58 PM
  #22681
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
its the stiff top deck (not to be confused with the 2.5 mm carpet top deck)
andrewdoherty is offline
Old 10-29-2007, 09:53 PM
  #22682
A quick question..I have been running the kit top deck in stock class but have broken 3 top decks..I have the flex top deck but just looking at it do not know where you would use it ( would tweak the car very easily)Is the stiff top deck the Go?
Barger is offline
Old 10-29-2007, 10:25 PM
  #22683
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
The "stiff" top deck basically feels just like the stock top deck on the track, but doesn't hold tweak as easilly. I don't run anything else for asphalt and rubber tire carpet.
Randy Caster is offline
Old 10-30-2007, 12:18 AM
  #22684
Thanks Randy....another question..the car is bloody heavy..(Light bulkheads should arrive next couple of days)running brushless and Lipos do you add weight to battery side of the car?
Barger is offline
Old 10-30-2007, 04:37 AM
  #22685
Big Features's Avatar
Originally Posted by justin lessard
Mike Kling-not a bitch
Hells NO!! My schuie was good enough for a top 3, but my driving was only good for 7th. Had a blast though, 13.5 and Lipo on rubber-tire carpet is nuts! I could bearly hang onto the thing
Big Features is offline
Old 10-30-2007, 05:02 AM
  #22686
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
with the core rc pack shifted all the way to the side make it flush with the chassis i only had to add about 2 1/2 ounces depending on what brushless esc/motor combo you are using
Marcos.J is offline
Old 10-30-2007, 05:31 AM
  #22687
Tim Kowal's Avatar
Was the 2 1/2 ounces to make the car balanced or was it enough to make legal weight? I have to had close to 100 grams or 3.5 ounces to make legal weight with the core pack and brushless.
Tim Kowal is offline
Old 10-30-2007, 05:36 AM
  #22688
Super Moderator
Marcos.J's Avatar
no tim just to balance it but i forgot to metion i had the 5 cell chassis with the receiver and pt on the right side
Marcos.J is offline
Old 10-30-2007, 06:02 AM
  #22689
abailey21's Avatar
Trader Rating: 37 (100%+)
3x8 is the lowest i have man.
Originally Posted by Randy Caster
Hey Adam, in the CORE screws, are there any 3x6 flathead packs?
abailey21 is online now
Old 10-30-2007, 07:11 AM
  #22690
I'm running brushless with NiMH packs, steel screws on 75% of the car, and stock bulkheads and I'm underweight, not sure how everyone seems to be overweight.
Old 10-30-2007, 07:12 AM
  #22691
Looks like my dremel is coming out soon thanks for checking!
Old 10-30-2007, 07:18 AM
  #22692
abailey21's Avatar
hold off on the dremel, I have some of the older Silver Arrows in 3x6 Part # sib-3006
Actually they're Hard nickel
and the TIR all i have is 3x6 countersunk
Old 10-30-2007, 07:29 AM
  #22693
ive never had a problem of being under weight
jimmy..maddison is offline
Old 10-30-2007, 07:38 AM
  #22694
abailey21's Avatar
very funny lol
Old 10-30-2007, 07:56 AM
  #22695
My sheer anal-ness makes me run the same screw because the others will look different
It's a problem I've had for years now.
